Question: is it difficult to drive dumptrucks?
   / Question: is it difficult to drive dumptrucks? #21
Heres a very expensive rollover
   / Question: is it difficult to drive dumptrucks? #23
Do you have manual transmissions down? If so, it's just a matter of adding a splitter if you're getting an older dump. 5 speed trans with 2 or 3 speed splitter. Then you'll have 1-1, 1-2, 1-3, 2-1, 2-2, 2-3, etc. All easy going up, tricky part is coming down when you can't come to a dead stop and you'll have to find what gear you need to be in. The ones I've run the engine rpm range is about 600rpm at idle and 1200-1500rpm at red line, so when you have to slow down quick and keep the clutch in for any period of time when speed is changing, you gotta find the right trans and rear gear combination.
The exciting part is when you downshift on a steep downhill for engine braking and the splitter jams between gears and freewheels.
   / Question: is it difficult to drive dumptrucks? #24
I started driving in March, and am self taught. I got 80 miles of interstate with a 5 speed Mac, and the next day my trainer failed to show, so the boss told me to take the load to Orlando and be CAREFUL! Gave me a different truck(an International cabover) and I made it 20 miles down the road and stopped and called him and told him there was something wrong with the truck as it would only go 25 mph max. We finally deduced that I was running wide open in 5 gear, at 25 mph and he told me to go back out and when I got wide open in 5th, reach around to the front of the gearshift lever, and pull that button up and then do the same 5 gears again.
My point being, you won't know what you don't know, and what you don't know will make a lot of difference in the outcome of what you are doing.
Oh, and that March that I started driving in, was in 1980. Since then I have worked in 3 different truck driving schools as an Instructor. I have seen people grasp the concept in a few days, and others that never did. I would seriously consider finding someone who either drives and is willing to part with some of their knowledge to you, or just find someone running dumptrucks off road who might let you burn some diesel while moving their dirt. Good luck and be safe.
David from jax
   / Question: is it difficult to drive dumptrucks? #25
I just take whole gears downshifting going down hills.
   / Question: is it difficult to drive dumptrucks? #26
Beware of brake fade, if you're looking at a unit with drum brakes - especially if you're pulling grades. Look for a unit with a good engine brake. Stopping is much more important than going. Juice brakes are also generally easier to maintain than air brakes
   / Question: is it difficult to drive dumptrucks? #27
Hey everyone,
This is a little off topic but I imagine some of you will be able to help me. I have two full size yellow construction backhoes and that's what I make most of my living with. Years ago I wanted to be a market gardener and I got a little toy Kubota tractor with bucket and hoe attachments. Well, being a market gardener didn't pan out as I'd hoped but it got me started in the world of excavation machinery and here we are eight years later.
Now I'm considering getting a dump truck cuz having a giant wheelbarrow sorta goes hand in hand with having a giant shovel. But I dunno anything about how to drive them firsthand. Obviously I've been around them quite a bit. Seen all kinds of master operators do crazy stuff. But I'm worried just about being safe at first.
Probably looking at like a 6 meter bed single axle like an old mack or Mercedes. Smaller delivery sized dumptrucks aren't really useful for moving real quantities of material and a full size 12 meter tandem wouldn't go up my driveway. The 6m single axle is going to be a tight fit as it is.
Anyways i generally go through life picking up big power tools and just figuring out how to use them. Carefully at first obviously, but still just figuring it out.
Never driven anything bigger than 4x4 suvs and the backhoes which are like 7 tons or something.
Any advice or insight? Is it easy enough to just drive the thing around and dump them on stable ground? We'll gloss over any licensing questions for now , I'm pretty rural in another country and that type of stuff doesn't come up too often working in the neighborhood. Thanks!
Watch overhead power lines!
   / Question: is it difficult to drive dumptrucks? #28
Air brakes have twice the stopping power of hydraulic. There’s a reason literally every class 8 truck has air.
   / Question: is it difficult to drive dumptrucks? #29
Nope. The reason that most class 8 trucks have air brakes is the ability to easily hook up to different trailers without having to worry about contamination of fluids.
   / Question: is it difficult to drive dumptrucks? #30
I used to drive a 16' cattle truck, a '68 Chevy 50 series, with a 2-speed splitter. Not a dump truck but similar in being a bigger truck, at least. I found it easier to drive a stick on this than a car. It seemed more forgiving. Like others have said, you have to realize you are bigger and heavier, so acceleration, braking, and maneuvering occur slower than with a car. I was driving one morning to the gas station for a state inspection so didn't have any cattle on board. Our narrow 2 lane unstriped backroads are hilly and winding. I lost my brakes at the top of a hill and the next curve was a 90 degree. Try as I might, I could not downshift. I went up on the bank a bit to make that turn at about 35mph, but the next problem was a series of curves with houses above and below the road. If I didn't have free rein of the whole road in those curves, it was unlikely that there would be a good outcome. I could not meet an oncoming vehicle or any vehicle on that road. I was still going downhill, but it wasn't as steep. I had to stop that truck before I hit those curves. All this is running through my mind along with split second decisions and still trying to downshift. I decided to put it in a shallow ditch on the slight uphill side on the left. After a lot of bucking und bouncing, the truck came to a stop right before I would've hit the curves and lost the stopping power of that ditch. Whew! I went by a tree while in the ditch and it tore off the left-hand mirror. I wasn't hurt at all except my thumb was a little tweaked after that bank turn and I had slid across the seat. The driver's side seatbelt keeper was missing, so I had to use the one from the passenger's side. My wife was driving behind me and you can imagine how frantic she was wondering what was going on. Bottom line is to know your truck, do the pre-drive checks to make sure fluids are topped up and everything is in working order, and be careful and safe.
   / Question: is it difficult to drive dumptrucks? #31
Was that a hydraulic brake truck or an air brake truck?
   / Question: is it difficult to drive dumptrucks? #32
Don't forget to let the bed down after you dump. We had a guy here, took off with the bed up. Took out all the power lines and red lights in town on his route. But, when he hit the river bridge, the I beam shut him down. That is why insurance is costly.
   / Question: is it difficult to drive dumptrucks? #33
It was hydraulic. It had a leak in the line that no one could find. Had to always check the fluid and top it off each time.
Wo
Wow! No parking brake or anything on those things? Like I know it won't stop you on a dime but at least slow you down a little? Glad no one got hurt
   / Question: is it difficult to drive dumptrucks? #35
Lots of stories on dumps and what can happen...
Behind my house I still find pieces of a dump truck delivering a load of gravel to the neighbors build in 1957 and it was a Chevrolet... lost brakes on a steep road and went down the ravine.
My friend had his dump on a job site and had one of the guys move dirt to another spot... he got into a soft shoulder and in slow motion laid it on the side which was a bank so it was stopped by the bank
Waste Management relief driver took out an entire Mobil home overhead electric ignoring route notes... rather than back up he made a loop through the park taking out all the power drops at 6 am...
The guy didn't lose his job and I can't understand why he didn't...
Dump delivering chips for me took out the phone and cable saying he wasn't focused on it...
   / Question: is it difficult to drive dumptrucks? #36
A small thing, but important. Remember when the bed is up.
   / Question: is it difficult to drive dumptrucks? #37
Wo
Yeah, me too. I didn't even think to use the parking brake as it had limited usefulness anyway. When I parked it, I'd always put it in gear and block the tires too.
   / Question: is it difficult to drive dumptrucks? #38
Wo
Air brake trucks with spring canisters have a pretty strong parking brake. Hydraulic brake trucks usually only have a transmission band brake for parking. Even if they actually worked which they never do on a old truck they aren’t strong enough to do anything.
   / Question: is it difficult to drive dumptrucks? #39
As far as it goes, I guess those vintage drivers like me had it much easier. I started driving dumps at 17. Project involved about 2 or 3 miles of highway running back and forth between the bank being dug up to build dirt roads. Early to mid 60's Chevy and GMC dumps, 5 speeds with electric 2 speed rears. Also drove some mid 50's R190 IH's. Forget the year but one truck was an IH with a 549 gas engine. The two speed rear was vacuum acutated and very touchy to say the least. Eventually moved up to the Ford Louisville tandem with the stinky V8 diesel with a 5x4. Thought that I had died and gone to heaven so to speak when I got to drive an almost new 74 Diamond Reo tri-axle with a constant torque Cummins 270 and a spicer 7 speed. That was when the state I was living in asked if I wanted a commercial license? Just send in a few more bucks. Simple times.
For starters, cover your rear view mirrors to force you to use the side mirrors for everything. Once you get your hands on a truck, familiarize with it at home then find a big parking lot and practice just like if you were learning to drive period.
Deere 310L (A53317)
Deere 310L (A53317)
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
Traxmax Stand-On Track Loader Skid Steer (A59228)
Traxmax Stand-On...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2014 Freightliner M2 106 24FT Reefer Box Truck (A59230)
2014 Freightliner...
