Question about RTZ
/ Question about RTZ #1
Sign_Guy
My dad gave me a RTZ 42 with 180 hours. I've never had a zero turn but is it normal when you are going full speed to have to constantly adjust your line by pulling back on one yoke? It doesn't veer much but just doesn't seem quite "right". Thanks much and I sure glad to of found this forum!
BTW, I love the mower, I can do my yard in about 1/8 the time it used to take me.
I am fairly mechanically inclined so don't be afraid to give me details.:D
/ Question about RTZ #2
Each side has its own independant hydrostatic pump, one needs to be adjusted so when both levers are fully foward you go in a straight line. There will be adjustments on the rods going from the handles to the hydropumps control arm. Mike
Thanks, I'll dig into it this weekend.
/ Question about RTZ #4
That was one reason I didn't want a Zero turn. Have to have both hands in use.
/ Question about RTZ #5
It's common that the nose will want to fall towards the downhill, so you have to stay live on the controls. It becomes second nature over time. You do this with a 'steering wheel' but don't even think about it. Same with any ZTR, Skid-Steer, etc... Some of the simple things you can check is for consistent tire pressures, and front caster wheel bearings.
Joel
/ Question about RTZ #6
My husband just purchased a used Cub Cadet RZT today. It has a 50 inch deck. It seems to be in good shape except one of the little deck wheels on the front is missing.
He was told the machine is 2 years old. It shows 236 hours on the hour meter. He paid $1500.
We received a sale paper from Home Depot today with the same mower for $2999.
Did he make a good deal or not?
This will be our first Zero Turn Mower. We currently own a John Deere L130.
It takes forever to mow about 3 acres around our home some of which is rough and uneven.
Does anyone have any thoughts or hints about maintenance and usage of the RZT?
Thanks for any replies!
/ Question about RTZ #7
Price sounds reasonable. Hours might be a bit high for that age but it shouldn't hurt it if it was maintained well.
/ Question about RTZ #8
rzt good for 1 acre or less should have found a z force.
/ Question about RTZ #9
I'd let about 2 acres of that 'go to field'.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
