Question about Kubota Third Function Valve Operation
/ Question about Kubota Third Function Valve Operation #51
She must have worked for a different gummit. :)
I always have to laugh, well sort of a cross between that and cringe when I hear people talking about the highly paid government workers. I don't doubt they exist, I've just never met one and one sure doesn't live with me.
Thanks again to everyone who offered constructive advice, it has been helpful. I'm pretty sure it is the relief valve I'm hearing when the flow is overly restricted. That is why I opened the flow up some more. I'm trying to balance the valve operation while providing enough flow to keep the system happy.
As I said in a previous post I'm sure it has a lot to do with the fact that my grapple/thumb only uses a single 2" cylinder. When I built it I did not want to make the hydraulics so powerful that it caused other parts to break so I stuck with a single 2" piston. It has always been powerful enough to do what I want, but I may try a 3" cylinder to see if it slows things down a bit.
I still have the fall back of using the rear remotes which work great.
/ Question about Kubota Third Function Valve Operation #53
You don't want to pop your relief valve much, but a little bit won't cause issues. Popping the relied valve will heat up the oil & put a maximum load on the pump. But a 5-10 seconds of relief every 5-10 minutes or so won't be significant compared to normal hydraulic system operational heat generation.
I have restrictors on my TnT & hear relief kicking in when operating them. No issues here. I know FitRite sells a lot of em & I haven't heard any complaints or issues. Other than a few people drilling theirs out a hair wanting slightly faster operation.
/ Question about Kubota Third Function Valve Operation #54
Devildog, question for ya...purchased a used L3240 and am installing a factory 3rd function valve for a grapple, got the kit and instructions are not good, wondered if I could get a few pics of your hyd connections, thanks
/ Question about Kubota Third Function Valve Operation #55
Hi EZ
I had been looking fir a solid low hour 3240 cab for about a year before I said To myself, is that what I really want?
I kind this was a couple of years ago, but I wanted to know how you made out, and of you are still using the 3rd function with a grapple?
Don
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2019 DODGE CHARGER (A59823)
2019 DODGE CHARGER...
