Question About engaging PTO
   / Question About engaging PTO #71
With some of the electrically actuated PTOs, depressing the clutch doesn't help, unfortunately. There doesn't appear to be anyway to feather the engagement.
What about on-off-on-off-on type of feathering?
   / Question About engaging PTO #72
I don't know, actually..I'm a "lever" guy.
Best advice I can suggest is to engage at as low an RPM as possible...
   / Question About engaging PTO #73
   / Question About engaging PTO #74
My tractor has a lever too, but the electric just electrically shifts a valve I am manually shifting. Like you, I don't know if it will work with electric, but I believe it should work.
Just my novice opinion but I think Kubota need to add the soft engage PTO option to their tractors with electronic PTOs. My bailer on the M4070 electronic PTO engages fine which tells me the LandPride rotor cutter could be improved. I use the New Holland on the 11 FT bush hog. The New Holland does not have an electronic PTO so I can't compare. The blades are tight on the land pride and stop in the cutting position (completed extended). If I manually push the blades forward, before engaging, I get an acceptable start, just a little shuffle and no big bang. I am think all that is required is to get the blades loosen up which would allow the blades to swing forward on disengagement.
I don't think the big bang I have been complaining about is going to break the land pride but I would like to eliminate it if possible.
This was my first post on the forum, I am very impressed with the knowledge and sharing. Thanks.
I have tried the on off feathering from day one. The big bang scares me so much, I cut it off the first try.
   / Question About engaging PTO #77
Have you discussed this with your dealer? I expect some shuttering and a little noise on all our tractors, but I never get the big bang you are describing and would be concerned. Is there anyway you can upload a video of this, some TBN members have done so which gives us all a better understanding of he issue.
   / Question About engaging PTO #78
...but I never get the big bang you are describing and would be concerned.
"Big bang" is pretty subjective. My old Land Pride cutter made a pretty loud "bang" when the blades extended...even at idle (1000) RPM. Once the blades extended, and that vibration from the imbalance subsided, it wasn't too bad. The Woods Brush Bull I have now seems to make a lot less racket during the initial engagement.
   / Question About engaging PTO #79
You need to get out there and mow a few acres to get those blades loosened up. They aren't supposed to be tight, but usually are when new. Talk to your dealer also...
   / Question About engaging PTO #80
Yes it is subjective, but when I hear the noise is like hitting the cutter with an 8 pound hammer that "seems" a lot louder than anything I have ever used.
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
2010 Ford F-150 (A50323)
2010 Ford F-150...
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
2018 JLG SKYTRAK 6036 TELESCOPIC FORKLIFT (A51242)
2018 JLG SKYTRAK...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
