Question About engaging PTO
   / Question About engaging PTO #61
Im glad for your good fortune.
,,,. My experience is that fasteners are sized to stabilize the joint against any movement, and the joint material is of like strength to endure the bolt force. After seeing multiple bolts loosen multiply on my dad and me copying him I began to tighten fasteners to their full spec when the joined parts were sufficiently robust to take it. Thats the only way Iv found to produce a long term secure joint under load reversal and shock conditions.
First I've ever heard of those high torque rates for those bolts (bush hog blades). Glad it works for ya. No disrespect intended.
   / Question About engaging PTO #62
I am sure I can bypass the switch on electronic PTO to make this happen. I will be in contact with the dealer next week to be sure the blades are correct. I am wounding why the blades are bent down and back up but are not clearing the pivot bolts. I wish I knew if the blades should be clearing the pivot bolts but that is not something people check unless they are having a problem. If I can't get the blades modified, I will consider you suggestion.
Most of these clutches may have a electric switch or cable to engage the PTO but the clutch itself is a hydraulic multi disc clutch pak and either the discs are engaged with the driven discs or the braking discs and there is little between the two and they are hard to feather. So bypassing and engaging switch while cranking will not work very well as there is no hydraulic pressure developed yet.
David Kb7uns
   / Question About engaging PTO #63
David Kb7uns
Hopefully it would engage as soon as the pressure starts to rise and would be less abrupt and at a lower rpm. :confused3:
   / Question About engaging PTO #64
I well remember when the -3 came out with the electric over hydraulic PTO was introduced, I posted I didn't want one, no way, no how. I have had one for a year and found it to be a non issue. I checked and the John Deere 4000 Series uses the same PTO engagement.
   / Question About engaging PTO #65
I'm sure it's fine, but I'd much rather clutch the PTO with a big cutter hooked up! :)
   / Question About engaging PTO #66
The clutch is pretty much a non issue with me as all of our larger tractors have independent PTO's in which depressing a clutch has no effect, they do however have the lever which I prefer as you can engage slower than the electric over hydraulic. I really liked the system on one of our Case tractors in which there was a halfway position where you moved the lever and a clutch began to rotate the PTO before going on to full engagement, really smoothed the engagement.
We use a fairly heavy Woods DS1260 10'6" pull type cutter with our M8540 and I can get smooth spool up with the lever. I don't know if any of the bigger tractors have the electric over hydraulic, I need to check. Our renters use a JD7000 Series with a Woods 15' bat wing.
   / Question About engaging PTO #67
I have an electric clutch on my JD 3032e
The best way I have found out to engage my pto is at about 1000 rpm's turn it on for a split second and once it moves ever so slightly then shut it off for a split second then back on
what this does is gets movement into the blades but not to the point of having them come around and hit the bolts
once there is movement I turn it back on and have no problems at all and take it up to my 540 rpm for the slasher
when I go to stop it I gradually take my throttle down until I get back down to 1000 rpm's and push the button down
only had problems once when I first got my little JD
now 300 hrs. later I got it down
   / Question About engaging PTO #68
Not sure about the Grand L 40 series but looking on my service manual for the L3130GST it does show an accumulator in the circuit for the PTO, the oil supply comes from the regulating valve for the GST transmission with oil suppliede from power streering section of the hydraulic pump. The HST version gets oil supply from the charge pump.
Now if you could put a restrictor on the feed to the accumulator you would slow the engagement some and maybe playing with the spring you could also change how hard it brakes the shaft when stopping, you do want good pressure on the clutchpak to prevent slipping though.
David Kb7uns
   / Question About engaging PTO #69
My brother in law works for a farmer in central IL (about 6000 acres) and they have all John Deere equipment. The tractors I have been in are a 7220, 8200, 8330, 8295R, 9430 and the combine is a 9760STS. I have been in all the above machines while they were operated and have spent time operating 3 of them myself, all of them have the same electric pto engagement that my 5240 does. My 5240 sounds like it engages the brush hog kind of rough until you hear a 200+ hp tractor engage the auger on a 1000+ bushel auger wagon, it sounds really rough! Lol. However they put thousands of hours on this equipment with zero pto issues.
   / Question About engaging PTO #70
Thanks for the information, that will save me a trip up into one. I have never driven one, but had to go up into one about a year ago to leave some instructions and man there sure was a lot of stuff in there and it made our "biggest" tractor fee like a toy.
Those guys do stuff with those big machines that it is hard to believe unless you see it, sure lets you know the difference between someone like me and someone who does it for a living.
Livestock Stall Fan Cage (A50515)
Livestock Stall...
20' Sea Container (A50774)
20' Sea Container...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
John Deere BD1113 Grain Drill (A52128)
John Deere BD1113...
Little Giant Poly Water Tank (A50515)
Little Giant Poly...
