Question about electrical connector on DK 40SE
   / Question about electrical connector on DK 40SE #1
JohninCT
Platinum Member
Central CT
Struck Magnatrac 6000, Kioti DK40SE
I am a new owner of a DK 40SE. There is an unused/unconnected electrical connector at the left rear of the tractor. Can someone tell me what this connector is used for?
   / Question about electrical connector on DK 40SE #2
No one has answered you yet. I don't actually know what it is but my dealer told me it was for trailer lights. Not sure if that is correct.
   / Question about electrical connector on DK 40SE #3
It is probably the 'owner use circuit'. Check your fusebox for an extra fuse marked 'customer use'. Run a test light to ground and see if it is a live circuit when the tractor is running; it may be controlled by a switch near the 'console' - check owner's manual for location of switch. Pull associated fuse to verify the particular circuit/fuse, and see if test light goes dead.
   / Question about electrical connector on DK 40SE #4
I thought that it might be for cab lighting if you were to opt for a hard cab....Mike.
   / Question about electrical connector on DK 40SE #5
There is also one of those connectors on the CK models and there is no cab options for CKs. Email Wallace Equipment, he will know.:rolleyes:
Thanks for the replies. I'll have to look at it a little closer and check it out with a test light.
   / Question about electrical connector on DK 40SE #7
mine has a round plug with more than two wires, Its for trailer lights "left right rurn signals, electric brakes, run lights.
   / Question about electrical connector on DK 40SE #8
Deon, Have you found out what that connector is for? I also have the same Kioti.
THANKS,
elstonb NH.
   / Question about electrical connector on DK 40SE #9
If it is on the rear of the tractor usually on the passanger side it is for a optional rear work light.
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A56435)
2018 Cadillac...
2021 Ford F-450 (A55973)
2021 Ford F-450...
TANK MANIFOLD (A58214)
