Question about electrical connector on DK 40SE
   / Question about electrical connector on DK 40SE #1
JohninCT
Platinum Member
Central CT
Struck Magnatrac 6000, Kioti DK40SE
I am a new owner of a DK 40SE. There is an unused/unconnected electrical connector at the left rear of the tractor. Can someone tell me what this connector is used for?
   / Question about electrical connector on DK 40SE #2
No one has answered you yet. I don't actually know what it is but my dealer told me it was for trailer lights. Not sure if that is correct.
   / Question about electrical connector on DK 40SE #3
It is probably the 'owner use circuit'. Check your fusebox for an extra fuse marked 'customer use'. Run a test light to ground and see if it is a live circuit when the tractor is running; it may be controlled by a switch near the 'console' - check owner's manual for location of switch. Pull associated fuse to verify the particular circuit/fuse, and see if test light goes dead.
   / Question about electrical connector on DK 40SE #4
I thought that it might be for cab lighting if you were to opt for a hard cab....Mike.
   / Question about electrical connector on DK 40SE #5
There is also one of those connectors on the CK models and there is no cab options for CKs. Email Wallace Equipment, he will know.:rolleyes:
Thanks for the replies. I'll have to look at it a little closer and check it out with a test light.
   / Question about electrical connector on DK 40SE #7
mine has a round plug with more than two wires, Its for trailer lights "left right rurn signals, electric brakes, run lights.
   / Question about electrical connector on DK 40SE #8
Deon, Have you found out what that connector is for? I also have the same Kioti.
THANKS,
elstonb NH.
   / Question about electrical connector on DK 40SE #9
If it is on the rear of the tractor usually on the passanger side it is for a optional rear work light.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
John Deere 5115M (A57148)
John Deere 5115M...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
25ft Tag Trailer (A56435)
25ft Tag Trailer...
Takeuchi TL10 (A57148)
