question about checking Fel hydraulic pressure on 3320
   / question about checking Fel hydraulic pressure on 3320 #11
Hydraulics:
Type: open center
Capacity: 9.6 gal [36.3 L]
Pressure: 2500 psi [172.4 bar]
Pump flow: 12 gpm [45.4 lpm]
Total flow: 17.1 gpm [64.7 lpm]
Steering flow: 5.1 gpm [19.3 lpm]
To check for aeration, remove a bucket hose and place in a bucket and cause fluid to flow. Look for small bubbles.
Hydraulics:
Type: open center
Awesome! Thank you sir
   / question about checking Fel hydraulic pressure on 3320 #13
Hydraulics:
Type: open center
I think those are the specs for a 4x20 JD
   / question about checking Fel hydraulic pressure on 3320 #14
try cheching the front filter screen . Mine got junk in it at 60 hrs , caused problems with hydro jd could not find problem, so i change fluid+filters at 90 hrs turn out ft screen was cloged up been great sence got 180 hrs now 3320 are good units
   / question about checking Fel hydraulic pressure on 3320 #15
There have been a few threads about this issue. Try searching for cavitation on 3000 series. Seems to be more of an issue at idle and with cold fluid if I recall.
Matt
   / question about checking Fel hydraulic pressure on 3320 #16
Did you ever solve this issue? I'm chasing the exact issue.
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2017 Chevrolet Impala (A56859)
2017 Chevrolet...
2014 Mercedes GL550 AWD SUV (A56859)
2014 Mercedes...
