question about checking Fel hydraulic pressure on 3320
   / question about checking Fel hydraulic pressure on 3320 #11
Hydraulics:
Type: open center
Capacity: 9.6 gal [36.3 L]
Pressure: 2500 psi [172.4 bar]
Pump flow: 12 gpm [45.4 lpm]
Total flow: 17.1 gpm [64.7 lpm]
Steering flow: 5.1 gpm [19.3 lpm]
To check for aeration, remove a bucket hose and place in a bucket and cause fluid to flow. Look for small bubbles.
Hydraulics:
Type: open center
Awesome! Thank you sir
   / question about checking Fel hydraulic pressure on 3320 #13
Hydraulics:
Type: open center
I think those are the specs for a 4x20 JD
   / question about checking Fel hydraulic pressure on 3320 #14
try cheching the front filter screen . Mine got junk in it at 60 hrs , caused problems with hydro jd could not find problem, so i change fluid+filters at 90 hrs turn out ft screen was cloged up been great sence got 180 hrs now 3320 are good units
   / question about checking Fel hydraulic pressure on 3320 #15
There have been a few threads about this issue. Try searching for cavitation on 3000 series. Seems to be more of an issue at idle and with cold fluid if I recall.
Matt
   / question about checking Fel hydraulic pressure on 3320 #16
Did you ever solve this issue? I'm chasing the exact issue.
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A56858)
2006 International...
CRAFTSMAN PUSH MOWER (A58374)
CRAFTSMAN PUSH...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2009 Ford Crown Victoria Passenger Car, VIN # 2FAHP71V79X115619 (A57453)
2009 Ford Crown...
