question about checking Fel hydraulic pressure on 3320
   / question about checking Fel hydraulic pressure on 3320 #11
Hydraulics:
Type: open center
Capacity: 9.6 gal [36.3 L]
Pressure: 2500 psi [172.4 bar]
Pump flow: 12 gpm [45.4 lpm]
Total flow: 17.1 gpm [64.7 lpm]
Steering flow: 5.1 gpm [19.3 lpm]
To check for aeration, remove a bucket hose and place in a bucket and cause fluid to flow. Look for small bubbles.
Hydraulics:
Type: open center
Awesome! Thank you sir
   / question about checking Fel hydraulic pressure on 3320 #13
Hydraulics:
Type: open center
I think those are the specs for a 4x20 JD
   / question about checking Fel hydraulic pressure on 3320 #14
try cheching the front filter screen . Mine got junk in it at 60 hrs , caused problems with hydro jd could not find problem, so i change fluid+filters at 90 hrs turn out ft screen was cloged up been great sence got 180 hrs now 3320 are good units
   / question about checking Fel hydraulic pressure on 3320 #15
There have been a few threads about this issue. Try searching for cavitation on 3000 series. Seems to be more of an issue at idle and with cold fluid if I recall.
Matt
   / question about checking Fel hydraulic pressure on 3320 #16
Did you ever solve this issue? I'm chasing the exact issue.
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
453 Detroit Diesel Engine (A59213)
453 Detroit Diesel...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2016 Ford Expedition (A56859)
2016 Ford...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
