Question about brush cutter...
/ Question about brush cutter... #1
RandyH
Cordova, Alabama
Yanmar 1500
I'm trying to adjust the front to back height on my brush cutter. I understand the back should be 1-2" higher than the front. The top link on my 1500 doesn't appear to take up enough to get the front off the ground. Do you normally have to raise the front of the cutter using the 3-pt hitch to get the desired angle?
Thanks,
Randy
/ Question about brush cutter... #2
<font color="blue"> Do you normally have to raise the front of the cutter using the 3-pt hitch to get the desired angle?</font>
Randy,
Use your lift to set the hight of the front first. Then you can use the tail wheel to get the angle you want or need. When you get done setting it up, you should have slack in the top link when everything else it set and ready to mow.
/ Question about brush cutter... #3
You will have to have the 3p pt hitch adjusted somewhere above the bottom. After I set mine up, I mark the lever setting with a pencil so I can return to the same setup after raising or lowering the cutter. It is unhandy, but I haven't found a better way to do it. Maybe someone has a suggestion?
Ok, then you do have to use the lift to set the front end height. Then I may have a problem...if I lift an implement with the 3 pt. hitch, the implement will not stay up unless I keep the lever in position. If I let go of the lever, the implement drops, and the lever goes back to the down position. Is this normal? I thought when I lifted something, it should stay lifted unless I moved the lever.
Thanks for the help.
Randy
/ Question about brush cutter... #5
Look on the handle that raises and lowers the 3 pt. There should be a screw that goes through it that keeps it against a curved piece of metal. Check to see how loose that screw is. It may need tightening. There is a friction disk in there also. It looks like a plastic washer. It could be missing.
/ Question about brush cutter... #6
If the lever goes down.. the implement is going to go down.
on my 1700, I used a piece of rubber to make friction against the lift quadrant to keep the 3pt lever in place.
Soundguy
</font><font color="blue" class="small">( Look on the handle that raises and lowers the 3 pt. There should be a screw that goes through it that keeps it against a curved piece of metal. Check to see how loose that screw is. It may need tightening. There is a friction disk in there also. It looks like a plastic washer. It could be missing. )</font>
Thanks, Brent, I'll look at that.
Brent,
I just looked at the screw..it was totally loose! I hand tightened the nut against the spring. I think that has got it.
thanks, again.
Randy
/ Question about brush cutter... #9
Normally your rear wheel will be set and bolted in, so when you adjust the lever to the correct height, their should be a screw stop with a wingnut to set so it can't drop lower than that point, plus friction should hold the handle in place when you lift the implement. Set your toplink so the implement does not hit the driveshaft when lifting and/or your swivel link is vertical for maximum rise/fall in following terrain. A set of check chains is also a good idea for maintaining the front height of the cutter and keeping pressure off the 3ph.
/ Question about brush cutter... #10
I use a spare pinn through a heavy ring amd one of the top link ath-pointts on my tractor and a chain with s-hooks to set the height of the frount of the cutter. The pin is passed through the ring and then the chain through the ring attach to the lift points and take up the slack. just droup the cutter and it will always be at the height you set it every time and no worry about hitting the leaver.
/ Question about brush cutter... #11
Randy I think 1 - 2 inches is too much. Maybe you meant 1/2" ?
cvt
</font><font color="blue" class="small">( Randy I think 1 - 2 inches is too much. Maybe you meant 1/2" ?
cvt )</font>
No, the brush cutter manual I downloaded (Bushhog brand, I think) said to set back of cutter 1-2" higher than the front.
RandyH
/ Question about brush cutter... #13
Having the rear a little higher than the front (an inch or two is fine) is best for cutting faster and clearing the clippings out from under the deck; the grass is getting cut at the front of cutter. Having the front a little higher than the rear is best for mulching the clippings smaller; the grass gets cut at the front of the cutter and again at the back. Just depends on how you want to do it. Personally, I did it with the rear higher.
/ Question about brush cutter... #14
I cut with the front lower than the rear. I don't have a chain guard on the fron of my cutter. /forums/images/graemlins/blush.gif
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2021 Kubota RTVX1120 (A64127)
2021 Kubota...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2022 EZ-GO ELITE...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A59914)
2012 FORD E-350...
