Question about a grapple
/ Question about a grapple #101
There are no update photos this morning, because Mike being the religous person that he is, stopped working at sundown Saturday and will not pick up a tool until sundown Sunday. Yes, this is a serious post. /forums/images/graemlins/wink.gif
Ron this is a picture of the modification that we mentioned earlier on the toothbar. The center tooth needed to be moved slightly to the right so it wouldn't interfere with the center lift arm on the grapple.
I'm really getting antsy waiting for the center lift arm and rear pivot to show up. I'm expecting to see it tomorrow UPS. In the meantime I cut the two pieces of 2 X 2 X 1/4 inch square tube that will be used to tie all three lift arms together. Can't tack weld them together as of yet because both tubes will pass directly through the center lift arm.
/ Question about a grapple #105
Mike
I hope you get it done soon. You are tying up a lot of TBNer’s. Watching for this project to be completed. /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
/ Question about a grapple #106
Looking great Mike /forums/images/graemlins/grin.gif Keep up the good work. I'm probably just as excited for UPS to arrive as you are.
/ Question about a grapple #107
Hmmmm ...... is that some fresh paint I see ?
/ Question about a grapple #108
Who is Chesterfield????????? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
<font color="blue"> Hmmmm ...... is that some fresh paint I see ? </font>
Good eye....yes I started splashing a bit of semi-gloss black on the bucket.
Chesterfield is a brand of cigarettes Junk why do you ask. /forums/images/graemlins/grin.gif
/ Question about a grapple #110
</font><font color="blue" class="small">( Who is Chesterfield????????? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif )</font>
Sharp eye JunkMan!
It is written on the 2x2 box in the one picture...
Maybe that is the name of the laboror he hired to keep the shop so cleen and go pick up parts? /forums/images/graemlins/shocked.gif
I purchase most of our steel from a local supplier that buys large salvage lots for resale purposes. (Summit Equipment) I suspect that this load may have originally been intended for a company or person by that name as it was marked with a paint stick.
If Chesterfield comes looking for his steel later on he isn't going to recognize it once we get finished with it. /forums/images/graemlins/wink.gif
The lower arm pictured is the center lift arm. It has cutouts to permit the 2 X 2 tubes to pass through it.
The bushing on the center lift arm is much longer than the outer arms to accommodate the width of the hydraulic cylinder that will attach to it. You can see the difference in the outer and center bushings in this picture.
Center pivot/cylinder mount being aligned for position.
Cross tubes positioned and tack welded.
At this point the business end of the grapple is removed by sliding out the alignment rod. It's not so heavy that it can't be easily lifted from the bucket.
Gussets added to strengthen the grapple tips.
Another view...
Especially for you Junk !
YYSIUA = Yes, you screwed it up again
Seems we miscalculated on the length needed for the height on the center cylinder support. After close measurement we are a full 1-1/2 inches too short.
This means we have no choice but to cut another center pivot/cylinder support.
/ Question about a grapple #120
"This means we have no choice but to cut another center pivot/cylinder support. "
Bummer!
I guess you should have bought that plasma cutter after all!
PS. Why isn't this in the Build-it forum /forums/images/graemlins/confused.gif
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2015 Volvo 85160 4yd. Loader Bucket Attachment (A64553)
2015 Volvo 85160...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
