Backhoe question about 3 pt hitch backhoe
   / question about 3 pt hitch backhoe #1
searcher1899
sunman IN
Foton
I have a 40 hp 4x4 tractor (farm pro) it does not have a front end loader on it. does anyone know if a 3 pt hitch back hoe would work ok on the tractor. I do not know anything about these type of backhoe. I do not need a front end loader and do not want to tie the tractor up with anything permently mounted to it.
   / question about 3 pt hitch backhoe #2
Might have issues with the front of your tractor moving a lot while digging without the loader as well as a very light front end. The 3ph backhoes tend to stick way out and ruin your capability to traverse rough areas because of it. You'd probably be better off trying to find 1 that is quick attach with bolt on frame mounts. The bolt on also won't have the tendency to sway when traveling like a 3ph will.
   / question about 3 pt hitch backhoe #3
I agree about having issues with that set-up. About the same as having a loader with nothing on the 3PH and no fluid in the tires. To have a good experience with either one it needs to be outfitted correctly.
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A58018)
1998 CHEVEROLET...
5TH MOUNT FOR PICKUP / DOLLY (A52708)
5TH MOUNT FOR...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
Ford 8510 (A53317)
Ford 8510 (A53317)
2001 KENWORTH T800 BOBTAIL KILL TRUCK (A58214)
2001 KENWORTH T800...
