npalen
Elite Member
Was reading a bunch of old threads on Kubota's inching valve on the 3PH. It occurs to me that this is simply a mechanical method of controlled "bumping" any hydraulic valve to get a small amount of cylinder movement.
With this in mind, it would seem that such a system would be useful for the lift function on a front end loader (FEL). Many times a person wants to raise or lower the bucket a very small amount and very slowly. This is particularly true when a heavy load is being moved into position when using the FEL as a "crane".
I've even resorted to bracing my arm against something or even grabbing the valve handle with both hands so that it could be moved ever so slightly. Have you ever just "tapped" an adjustment of any kind to get a small movement of the device or function being controlled?
So then the thought process leads to a "flipover device" on the loader valve handle that is adjustable just like the quarter inching valve but could be flipped out of the way when not needed.
Thoughts?
Thoughts?
