PVC Pipe on cutting edge of snow blade
   / PVC Pipe on cutting edge of snow blade
If you just turn the blade around backwards, it will work fine and you won’t have to mess with contraptions.
You're going to have to explain how that trick works.....
   / PVC Pipe on cutting edge of snow blade #22
   / PVC Pipe on cutting edge of snow blade #23
He was probably thinking about a rear blade on a tractor. Most of those will pivot and can be spun around backwards.
Yeah well, that reversing the blade doesn't work well with heavy wet snow. Tried it a few times, snow doesn't like to slide across the back of the blade as well as it does the front.
   / PVC Pipe on cutting edge of snow blade #24
Because you use it in reverse and it acts like the front blade on a truck
My betting money is on you
   / PVC Pipe on cutting edge of snow blade #27
It actually does if you get the top link angle and blade angle set right it will roll even wet snow.
   / PVC Pipe on cutting edge of snow blade #28
Contact this guy, he is a regular member from Michigan over on the green tractor forum, he can teach you all about snow removal and the right "edges" ... And make what you need for your particular equipment ... https://www.sulleybearsolutions.com/shop
He uses different plastics, and rubber to not hurt your pavement, gravel, or even lawn, AND improve the snow clearing end effect.
20 BLADE DISC HARROW, 3PT (A52708)
20 BLADE DISC...
2008 Toyota Rav 4 SUV (A56859)
2008 Toyota Rav 4...
Pallet of 10 Chains and 5 Binders (A57454)
Pallet of 10...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2026 Anvil T/A Enclosed Trailer (A56859)
2026 Anvil T/A...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
