putting green
/ putting green #1
newtractorowner
does anyone know how to construct a putting green? I have an area about 35' in diameter scraped down to the hard pan clay. I wonder if I can just put top soil over the top of the clay. How much slope to the hole? Any help would be great.
Thanks
/ putting green #2
A friend of mine worked on a grounds crew, and we discussed this topic a few years ago.
Once you have a compact, graded surface (your clay), dump approximately 6-8 inches of #2 stone, which is then topped with quarry dust and packed down firm. This apparently provides a stable, yet porous base, allowing your topsoil to drain.
According to my buddy, this is where you will shape the surface of your green, by providing the undulations/breaks, etc.
You will then top your green with 10 inches of the finest topsoil that you can afford. There are a number of varieties of grass that work well in different areas of the country.
For drainage, remember: the slope of the clay should reflect where you want the water to drain. Good luck.
/ putting green #4
newtractorowner,
Check with Murf over on the Compact Tractor Board. His company builds golf courses in Canada and the northern U.S. http://www.jplan.com
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
