Putting a Meyer's power angle on a Ford NAA
   / Putting a Meyer's power angle on a Ford NAA #11
I can't take credit for it. I've seen it used for a front scrape blade, and a small nose lift for a trailer on other antique ford tractors with 3pt lift.. but not much ability for external hyds..
soundguy
   / Putting a Meyer's power angle on a Ford NAA #12
I assume you coud fill one cyl via hyds thru the hose, fill the other and expel a bit, and then union the hoses with a 3-way female pipe T and add make up oil, then plug..
soundguy
Have you actually done this trick? :)
   / Putting a Meyer's power angle on a Ford NAA #14
I have done something similar while dinking with loader hyds on a couple of my machines where I had limited external hyds capability.. I was actually using the 3pt for one cyl, and a rigged remote for another... finally got a different setup and laid it to rest.. :)
soundguy
   / Putting a Meyer's power angle on a Ford NAA #15
I'm going to try Soundguy's idea. I have two cylinders unused from a woodsplitter project. They were too small for that but will work fine for this. Now I just need to mount the Meyers on the front of my tractor. didn't want to cut into any of the truck mounting brackets as then i can't sell it for that use.
   / Putting a Meyer's power angle on a Ford NAA #16
if they are da cyls, just put a breather plug in the unused port but not a sealed plug...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2016 KUBOTA SVL95-2S TRACK LOADER (A50854)
2016 KUBOTA...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2013 Honda CR-Z (A50324)
2013 Honda CR-Z...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
