Puter Guru's
/ Puter Guru's #1
RedRocker
Bowie TX
Kioti CK30 HST, dual remotes, FEL.
Puter Guru\'s
I'm running XP on a Viao laptop, for some reason pictures, especially attachments I open look very pixelated. I can look at a memory stick from my camera and it looks great, but most everything on the net looks like it was taken with a cheap camera. Any ideas? I've messed around with the settings without much luck. /forums/images/graemlins/confused.gif
/ Puter Guru's #2
Re: Puter Guru\'s
Are you using a high speed dial up connection like Net-0, one way they speed things up is to reduce the resolution of images when they download. If your off-line pictures look OK it has to be something in your brouser or internet connection.
/ Puter Guru's
Re: Puter Guru\'s
Earthlink DSL . The avatars here look garbled as well as any attachments that I open.
/ Puter Guru's #4
Re: Puter Guru\'s
If you are using IE. Under tools, Internet options, Multimedia check the box for image resizing. You may have already tried this. But its a start.
/ Puter Guru's
Re: Puter Guru\'s
Yep, it's checked, no change. It's tough not having any kids that are puter literate. LOL
/ Puter Guru's #6
Re: Puter Guru\'s
A stab in the dark here...
Have you tried changing your settings in "Display Properties"?
Increasing your screen resolution might help.
/ Puter Guru's
Re: Puter Guru\'s
Thanks everybody, it was my browser, the accelerator dodad was on with my DSL. Turned it off and all is well, thanks for heading me in the right direction.
Caterpillar 446B Backhoe (A66285)
Caterpillar 446B...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2018 RAM 2500 (A65643)
2010 Case 580N (A60462)
2010 Case 580N...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
