Put a snow plow on the loader.
   / Put a snow plow on the loader. #22
Looks really nice! I have a Meyers plow sitting around and an unused blank skid-steer type blank plate and I was getting ready to do the same sort of thing. Can you curl the frame back to raise the blade instead of raising the loader each time to retain your reference point?
That is exactly what I am doing. Once the loader arms are at a set height that gives me a level a-frame and plow, I only use curl....as I can reference my bucket level indicator to go back to the exact same place every time
   / Put a snow plow on the loader. #25
yes I have that valve on my loader plow set up and I purchased it at the Surplus Center, it works great
Who is that reply directed at?
   / Put a snow plow on the loader. #27
I see a post on the double relief valve that was added to protect your hyd and hoses on the plow set up wow I posted it under the post and can't find it
   / Put a snow plow on the loader. #29
That is rather ingenious LD1.. Unfortunately on my forks they don't remove from the frame easily. But your solution seems like a great repurposing of something you already had on hand. A big thumbs up. :thumbsup:
My fork frame has a notch in the bottom lip just wide enough for a fork to come off. Slide one to the center, lift up at the tip, and lift off the top. It was literally a 30 second job
Skidsteer Wheel Tracks (A59814)
Skidsteer Wheel...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2017 Autocar Xpeditor T/A Heil Front Loader Garbage Truck (A59230)
2017 Autocar...
International 656 Utility Loader Tractor (A59814)
International 656...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
