Put a snow plow on the loader.
/ Put a snow plow on the loader. #22
Looks really nice! I have a Meyers plow sitting around and an unused blank skid-steer type blank plate and I was getting ready to do the same sort of thing. Can you curl the frame back to raise the blade instead of raising the loader each time to retain your reference point?
That is exactly what I am doing. Once the loader arms are at a set height that gives me a level a-frame and plow, I only use curl....as I can reference my bucket level indicator to go back to the exact same place every time
/ Put a snow plow on the loader. #25
yes I have that valve on my loader plow set up and I purchased it at the Surplus Center, it works great
Who is that reply directed at?
/ Put a snow plow on the loader. #27
I see a post on the double relief valve that was added to protect your hyd and hoses on the plow set up wow I posted it under the post and can't find it
/ Put a snow plow on the loader. #29
That is rather ingenious LD1.. Unfortunately on my forks they don't remove from the frame easily. But your solution seems like a great repurposing of something you already had on hand. A big thumbs up. :thumbsup:
My fork frame has a notch in the bottom lip just wide enough for a fork to come off. Slide one to the center, lift up at the tip, and lift off the top. It was literally a 30 second job
/ Put a snow plow on the loader. #31
this is a great idea...and i was about to order a blank plate....this is much better...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
10in Digging Tooth Bucket Excavator Attachment (A60352)
10in Digging Tooth...
