Push mower tipped over ... now won't start???
   / Push mower tipped over ... now won't start??? #1
Johntodd
Ripley, TN
Cub Cadet LTX1050
Hi!
I put my Poulon push mower on it's side to remove the blade for sharpening. Got it back together and it won't start. That was 3 days ago.
I pull the rope and the engine fires up and then dies. I thought maybe it was flooded, but it's been 3 days. The spark plug was dry when I removed it. Plenty of gas in the tank.
The engine *does* fire. It's like it's getting gas for a brief moment and then being starved out. There is no gasoline odor.
Any ideas?
Thanks!
-John
   / Push mower tipped over ... now won't start??? #2
Have you check flow from the tank?
Had a stubborn similar and found the vent blocked... ran fine with.cap off for testing.
   / Push mower tipped over ... now won't start??? #3
It's Poulan btw and possibly the float is stuck.
   / Push mower tipped over ... now won't start??? #4
Depending on which way you tipped it, is the air filter saturated with engine oil?
   / Push mower tipped over ... now won't start??? #5
Tip it the opposite way;) na I'd guess tipping it stirred up some crap that got in the carb. Will it stay running if you choke it or partially choke it?
   / Push mower tipped over ... now won't start??? #6
pull the air filter, make sure its not covered in oil, it happens sometimes depending what side you tip them
   / Push mower tipped over ... now won't start??? #7
Or there was some crud in the bottom of the gas tank that has now found a way to stop up the gas flow.
   / Push mower tipped over ... now won't start??? #8
I’d guess the air filter is soaked with oil.
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2020 JLG Telehandler (A49461)
2020 JLG...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
