Push mower tipped over ... now won't start???
   / Push mower tipped over ... now won't start??? #1
Johntodd
Ripley, TN
Cub Cadet LTX1050
Hi!
I put my Poulon push mower on it's side to remove the blade for sharpening. Got it back together and it won't start. That was 3 days ago.
I pull the rope and the engine fires up and then dies. I thought maybe it was flooded, but it's been 3 days. The spark plug was dry when I removed it. Plenty of gas in the tank.
The engine *does* fire. It's like it's getting gas for a brief moment and then being starved out. There is no gasoline odor.
Any ideas?
Thanks!
-John
   / Push mower tipped over ... now won't start??? #2
Have you check flow from the tank?
Had a stubborn similar and found the vent blocked... ran fine with.cap off for testing.
   / Push mower tipped over ... now won't start??? #3
It's Poulan btw and possibly the float is stuck.
   / Push mower tipped over ... now won't start??? #4
Depending on which way you tipped it, is the air filter saturated with engine oil?
   / Push mower tipped over ... now won't start??? #5
Tip it the opposite way;) na I'd guess tipping it stirred up some crap that got in the carb. Will it stay running if you choke it or partially choke it?
   / Push mower tipped over ... now won't start??? #6
pull the air filter, make sure its not covered in oil, it happens sometimes depending what side you tip them
   / Push mower tipped over ... now won't start??? #7
Or there was some crud in the bottom of the gas tank that has now found a way to stop up the gas flow.
   / Push mower tipped over ... now won't start??? #8
I’d guess the air filter is soaked with oil.
Lot of 5 Laptops (A48083)
Lot of 5 Laptops...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2022 John Deere 325G Skid Steer (A50657)
2022 John Deere...
Kalamazoo 8-6-W Metal Cutting Band Saw (A48083)
Kalamazoo 8-6-W...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2025 Wolverine GB-11-72W Grapple Bucket Attachment (A50860)
2025 Wolverine...
