Purple Ice
/ Purple Ice #11
Do my operating temps indicate an underlying problem with the radiator system?
Well...Personal experience here...My 1700 runs from 190 to 230 based on the ambient temp here in NC...We're hot like you are in GA in the summertime...The temp light is designed to come on around 235 degrees as the boiling point of water is 248 degrees with a 14 psi radiator cap...Keep in mind that I've added a water pump to help out...So I wouldn't worry if your temp consistently stays between 210 and 230...Just keep an eye on her and keep the radiator clean...You will be fine...I've never overheated...
/ Purple Ice
thank yall....i have a long weekend coming up and just to be sure i will flush my system out. Radiator was completely reworked and looked like new when I bought the tractor, so i'm not expecting any problem with it. also, i keep the radiator clean from trash, etc. i wash it off after every use just to be sure, and sometimes it is completely covered with leaves, etc. when i get through mowing. i'll let yall know my results.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KAESER COMPRESSOR (A60736)
KAESER COMPRESSOR...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2015 Komatsu HM400-3 (A60352)
2015 Komatsu...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2003 Dodge Ram 1500 Pickup Truck (A60352)
2003 Dodge Ram...
