Purchasing a Grapple...Which one??
/ Purchasing a Grapple...Which one?? #41
Hi Brad...No, I did not specify the hose length. It came with the grapple. I compared the hose length to the hoses on my WR Long 4in1 bucket, and they are the same length. So, I assume that WR Long puts the connector ends in the same place on the buckets as well as their grapples, thus using the same hose lengths and stock for both. Probably cheaper and simpler for them. I'll take some pics and post them in the next day or so. That way, you can get an idea on how the lines are rigged.
RPK...I have my hoses on the 4in1 wrapped for protection with spiral wrap used to hold bundles of wire together. You can get it in different sizes, (and colors), from an electrical supply outlet. This stuff is tough plastic and is like a spring or spiral. You wind it around the outside of the hose. I got the idea when I saw the larger wrap on the hydro lines of some much larger construction equipment. It is designed for hoses and wires and is flexibile and protects. I will wrap the lines on the grapple, too. You can also buy the kevlar sleeving...but it's more expensive.
Here's a link to what I mean so you can see the stuff, (there should be an electrical supply place near you, otherwise mail order it) :
Spiral Wrap, Cable Wrap, Abrasion Protection for Wires and Cables
That's also a good idea on the welding of some angle...I may do the same on mine.
/ Purchasing a Grapple...Which one?? #42
RedBug; Thanks for the link and idea for the spiral wrap. I have several lines on my backhoe and grapple that I think need added protection.
RPK
/ Purchasing a Grapple...Which one?? #43
Brad,
Here's a pic of the hose hookup...from the grapple to the tractor. I am guessing the hose length on the grapple is around 4 or 4 1/2 feet. On the grapple end, there are two T's where each hose is threaded onto. Each T goes to a cylinder end. Each cylinder gets the same pressure since it is T'd, thus opening/closing equally. The other end of the hoses have connectors, (male and female), which mate to my tractor connectors. That way you don't get the open/close circuits backward. My 4in1 bucket is exactly the same. Hope this helps.
/ Purchasing a Grapple...Which one?? #44
Dave - thanks a lot for taking the time to post that for me. I don't know if you are interested but I posted my bulkhead pictures in hydraulics. Cool set up you have I hope to complete mine by spring.
Brad
/ Purchasing a Grapple...Which one?? #45
Hey Dave the grapple looks great, I just ordered a 48" millonzi LD, it should be here in another week, It shipped out yesterday. I got it for $1,048 including shipping to FL. I mentioned TBN. Jackie Luster helped me out a bunch and is even sending me a free t_shirt. I pieced together a 3rd function valve from Surplus center after a lot of help from Larrry Guglio on here. He did the same. I've got $360 into the whole valve and all hoses and fittings and wiring. I ended up using a trim/tilt handle off a boating controls for my control switch. It fits tightly over my loader joystick AND is WEATHERPROOF! I was going to go with the Long 3rd function, but they wanted 650. locally. I'll post some pics after I get everything together.
/ Purchasing a Grapple...Which one?? #46
I use a "Quick Attach" 84" grapple on my TL100A 4X4 . It is the best made attachment i have seen . Im sure you can buy a smaller version to suit your tractor size . It is great for every job you can imagine . But keep in mind that a grapple with forward facing tynes does not stickrake as well as a verticle tyne rake does . If you run along the ground with the tynes nearly flat they will take any oppertunity to dig in and nose dive the tractor as the tyres flatten out . If you use it with the tynes at say 45 degrees to stop this from happening , they will force the dump valve to open and swing under as the leverage on the crowd rams becomes to great as your pile of rubbish grows or you hit a tough root . Im sure "Quick Attach" makes a verticle tyne rake with a hydraulic top clamp for this reason . It all depends on what your requirements are which type you need . You welcome to look at the 3 photos of mine in my gallery .
/ Purchasing a Grapple...Which one?? #47
Iron Horse, nice looking grapple. Awesome in fact. $5700??? Holy smokes! Skid Steer Attachments - Attachments Direct, Inc. I didn't see a vertical tooth model in their catalog though. :(
I looked through your gallery. Hope the highway patrol doesn't give you trouble at the scales hauling three tractors with that little Isuzu... :D
/ Purchasing a Grapple...Which one?? #48
G'day GinNB . "Quick Attach" call them the "Quick Claw" in the brochure . Yes they command a high price , but the quality is without question . I guess im just used to the prices for attachments here in OZ . That rake in my gallery owes me around $10,000 with our weak Ozzie $ , trucking to the harbour and then by boat to OZ then from the Brisbane port to me then the GST added . Its probably the best 10 grand ive spent . The main point i was trying to make was the comparison between vertical tynes and horizontal tynes for raking regardless of the brand or cost . The tip of the tyne on my rake to the pivot point is about 700mm , the pivot point to the top crowd ram link is about 230mm giving a ratio of around 3to1. A mere 1000kg of force on the tynes at 45 degrees whilst raking will exert 3000kg's on the ram . Depending on the forces imposed and the relief valve pressure setting it is easy to have the rake fold under . The vertical tyne rake such as the "Quick Claw" have a ratio of around 1to1 and do not have this problem making them better for raking . Re. the Nissan truck , it has a 32,000kg gcm with the load of tractors in the photo im still 11,000kg's under my legal weight .
/ Purchasing a Grapple...Which one?? #49
JustCountry...Welcome to TBN! That's a great idea using the waterproof trim rocker switch from a boat control. When you get your grapple...show us how you got things rigged up. That ought to be an interesting setup. Where in Fl. are you? I used to live in Orlando way back before it became like Los Angeles, and at Waycross...just northwest of Jacksonville.
Iron Horse...I also looked at your pics. That's some equipment you have. Good tip on the tooth angle. That's some stump puller. That would be good over in this country to use to reclaim fatlighter stumps. When I was looking at your pics, I was thinking that were in Florida or California...but did not recognize the flora. Then in your post you said OZ! Wow!
/ Purchasing a Grapple...Which one?? #50
Redbug, check his location by his avatar- he's from Orstraya mate! :) Cute, I didn't get it at first and was trying to figure out why his measurements were metric and the vegetation was almost tropical.
Good measurements, ratios, and things to look for in a rake/grapple Iron Horse. Those're good things to look for when picking a rake. As far as the hauling goes, it's hard to tell without looking up the weights, axle capacities, etc, but it looks like the rear axle of the truck is holding the weight of two tractors plus the front of the float. What's the gross rear axle capacity? Weights of the tractors? Ever had it scaled? I'm not dogging you- it just looks like it might be overweight. I've certainly been guilty a time or three.
/ Purchasing a Grapple...Which one?? #51
It does look a little light on the front axle as the towbar was to far back and had to much purchase on the truck and that trailer had too much deck in front of the bogie , fixed that know . In OZ we are allowed 6(ton) on the steer , 9ton on a single drive axle (if the truck has a 15ton gvm) , 16.5ton on the trailer bogie = 6+9+16.5=31.5ton . The rear tractor in the photo weighs around 4.5ton and the other two around 3.25ton each=11ton . The truck weighs 6ton and the trailer weighs 3.5ton=20.5ton all up . Take 20.5ton from my allowed 31.5ton GCM and that leaves 11ton to spare . GVM=Gross vehicle mass and GCM=Gross combined mass . Perish the thought i would ever run heavy....not like when i used to pull two trailers full of wheat with my old White 4000 with a combined weight of 100ton sshhhhh.
/ Purchasing a Grapple...Which one?? #52
I am very impressed and satisified with the WR Long grapple. I used the root rake more than I expected. Very good design!
/ Purchasing a Grapple...Which one?? #53
Just wondering...Claykin and Justcountry...did you get your grapples, yet? Enquiring minds need to know...And you better post a pic or three!
Just picked up my grapple on Sat. It came into the dealer about 10 days after ordering it!! The only problem was my 300CX loader hadn't arrived from Deere. I took some pics yesterday, and will post them this week.
I have to confess that I have been too busy playing in the snow with my nieces and nephews on sleds behind my XUV to actually do any "work" with the grapple yet!
/ Purchasing a Grapple...Which one?? #55
well here are some pics of the Grapple the day I picked it up in my truck, I'll keep the pics and info coming. I'm waiting on a few final fittings to clean up my hydraulic lines and to make a custom bulkhead.
/ Purchasing a Grapple...Which one?? #56
I think I've narrowed it down to the Millonzi LD 48", I noticed the FD sticker in the Ranger, are you a firefighter? I heard Millonzi beefed up the outer arms to 1/2" instead of 3/8" Is that correct? Also it looks like some added protection for the cylinder on the grapple arm! If you don't mind me asking, how much did it set you back? I am ordering a Kubota L3540 with 724 loader (third function factory set up to the front bucket).
/ Purchasing a Grapple...Which one?? #57
I am ordering a Kubota 3540, 724 loader with factory 3rd function valve added. I heard Millonzi beefed up their outer arms to 1/2" instead of 3/8". Looks like some added protection for the cylinder with the angle welded in the grapple arm too!:D
/ Purchasing a Grapple...Which one?? #58
IslandTractor said:
I routinely pop out roots or just whole small trees (why take the extra step of making a mess with a bush hog?). Pop'em out and put them in a burn or compost pile.
Island - Do you have more pictures you can share showing the progress of removing a rootball/tree? Also wondered what the grapple looks like in the "dump" position and how easy it is to pluck up a log laying horizontal on the ground. iow, can you get to it by tilting the bottom of the grapple in a full dump position and then drop it over the top of the log clamping down or do you have to "scoop" it?
/ Purchasing a Grapple...Which one?? #59
Hey guys, yes I am a Firefighter. Millonzi did beef up the outside tines to 1/2" and they made a plate to cover up the end of the cylinder and welded some flat bar louvers to protect the cylinder. It is really a nice unit. As far as full tilt pickup, yes thats what I love about it, you can come down right over top of anything you want such as a log or a tall pile of brush and crush it strait down and clamp on it. you dont have to scoop or try to roll something into. it's just like an extra little hand out in front!
As far as cost, its the most economical grapple out there. 845$ plus shipping was about 1070$ to me total. Make sure to mention this website for the 25% discount! If I had it to do over, I would buy the same one. :)
/ Purchasing a Grapple...Which one?? #60
I'll try to find some photos of a grapple/tree battle but it is actually easier to describe. For starters there is a lot of variation and unless you are taking out pretty much identially sized trees from the same area you will need to experiment a bit to find the most efficient method. It also depends a lot on what your loader capacity is. I have removed trees with my smaller Kioti CK20 very successfully but it often required different technique and more time than when I use the larger DK40se.
I almost always try to give the tree a little shove to begin with. That helps expose where the roots are and sometimes just knocks the tree over. If the roots are clear then I proceed to stick a tine or two of the grapple underneath and drive forward while lifting/curling the grapple. For softwood trees up to about 5 inches or so that is usually sufficient to rip them out of the ground. Sometimes it takes doing the same thing from a couple of angles and sometimes I'll push on the tree trunk while repositioning to see which way the tree wants to fall and to expose more roots. Same basic procedure with stumps.
It is very easy to pick up a log. Both ways work: either scoop and close the grapple or come down from the top with the grapple open then close and lift. Scooping is easy especially if you can push against a pile or other obstacle that keeps the log from moving. If you don't want the log to move then just come over the top. I've posted a couple photos of coming over the top to pick up a pile of debris.
The last two photos are just digging the grapple under a small tree and lifting it out. I don't recall but I probably used both the motion of the tractor and the lift of the loader to pop it out. Don't underestimate the "wedge" force generated by moving the tractor forward with the grapple under the tree.
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
2017 Versatile 260 (A64126)
2017 Versatile 260...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
