Ballast pumping calcium chloride at home
   / pumping calcium chloride at home #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
The legitimate calcium pumps for loading and emptying tractor tires cost $1000. Local dealer does not want to deal with calcium as he is strictly a Rim Guard enterprise. I just want to reuse the calcium in the tires I have to replace and was wondering if anyone used a cheap utility pump that actually worked with this briny solution.
   / pumping calcium chloride at home #2
. But I just dont see a small utility pump lasting long.
I don't need it to last long LD. I just want to do the 2 rears. I never want to see the inside of these rims again so I am looking for an economical alternative. This stuff can get heavy so there may be no such thing as a "cheap" pump to push calcium.
   / pumping calcium chloride at home #4
You can buy a little drill pump and use it have done that before spray a bit of oil in when you are done it may even work again if you do that.
   / pumping calcium chloride at home #7
drill pump or hand pump works just fine....
2360 (A58376)
2360 (A58376)
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A56858)
2022 Chevrolet...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
1620 (A58375)
1620 (A58375)
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
