Ballast pumping calcium chloride at home
   / pumping calcium chloride at home #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
The legitimate calcium pumps for loading and emptying tractor tires cost $1000. Local dealer does not want to deal with calcium as he is strictly a Rim Guard enterprise. I just want to reuse the calcium in the tires I have to replace and was wondering if anyone used a cheap utility pump that actually worked with this briny solution.
   / pumping calcium chloride at home #2
. But I just dont see a small utility pump lasting long.
I don't need it to last long LD. I just want to do the 2 rears. I never want to see the inside of these rims again so I am looking for an economical alternative. This stuff can get heavy so there may be no such thing as a "cheap" pump to push calcium.
   / pumping calcium chloride at home #4
You can buy a little drill pump and use it have done that before spray a bit of oil in when you are done it may even work again if you do that.
   / pumping calcium chloride at home #7
drill pump or hand pump works just fine....
PIPE RACKS (A58216)
PIPE RACKS (A58216)
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58216)
2010 MAXEY WELDING...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
Utility Cart (A59228)
