Ballast pumping calcium chloride at home
   / pumping calcium chloride at home #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
The legitimate calcium pumps for loading and emptying tractor tires cost $1000. Local dealer does not want to deal with calcium as he is strictly a Rim Guard enterprise. I just want to reuse the calcium in the tires I have to replace and was wondering if anyone used a cheap utility pump that actually worked with this briny solution.
   / pumping calcium chloride at home #2
. But I just dont see a small utility pump lasting long.
I don't need it to last long LD. I just want to do the 2 rears. I never want to see the inside of these rims again so I am looking for an economical alternative. This stuff can get heavy so there may be no such thing as a "cheap" pump to push calcium.
   / pumping calcium chloride at home #4
You can buy a little drill pump and use it have done that before spray a bit of oil in when you are done it may even work again if you do that.
   / pumping calcium chloride at home #7
drill pump or hand pump works just fine....
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
2318 (A58376)
2318 (A58376)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A56858)
2007 Oshkosh...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
