Ballast pumping calcium chloride at home
   / pumping calcium chloride at home #1
arrow
Super Member
Foster, RI
Mahindra 3016
The legitimate calcium pumps for loading and emptying tractor tires cost $1000. Local dealer does not want to deal with calcium as he is strictly a Rim Guard enterprise. I just want to reuse the calcium in the tires I have to replace and was wondering if anyone used a cheap utility pump that actually worked with this briny solution.
   / pumping calcium chloride at home #2
. But I just dont see a small utility pump lasting long.
I don't need it to last long LD. I just want to do the 2 rears. I never want to see the inside of these rims again so I am looking for an economical alternative. This stuff can get heavy so there may be no such thing as a "cheap" pump to push calcium.
   / pumping calcium chloride at home #4
You can buy a little drill pump and use it have done that before spray a bit of oil in when you are done it may even work again if you do that.
   / pumping calcium chloride at home #7
drill pump or hand pump works just fine....
John Deere HX15 Flex Wing Rotary Cutter (A50860)
John Deere HX15...
2018 Dodge Ram 4500 4x4 Enclosed Service Truck (A48081)
2018 Dodge Ram...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2002 Ford E-250 Cargo Van (A48081)
2002 Ford E-250...
