pump issue
   / pump issue #1
jasonhydraulic
massey 12
i built a loader for my vintage 12 hp garden tractor using an 11 gpm 2 stage wood splitter hydraulic pump and it worked great this year i decided to add power steering using a priority diverter valve set at 3 gpm to the steering so the problem i'm having is the steering works as it should but the loader is now insanely slow so the question is do i just need a bigger pump or is there something else i can do to speed up the loader
   / pump issue #2
You're using the wrong pump for that application. The 2 stage pump is most likely kicking out to low flow/high pressure when the flow divider is installed.
   / pump issue
what would you recomend for a pump it's only a 12 horse power tractor
   / pump issue #4
I would say something around the 0.3ci to 0.4ci. It will never be as fast as it was with the 2 stage pump, but it should match the hp of the engine. About 5 GPM at 2000 PSI. Some of that will go to the steering though-
   / pump issue
ok thanks i think i'm going to try a little bigger pump and repower it with a 20 hp engine if i have to
   / pump issue #6
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2003 Freightiner FLD120 (A56436)
2003 Freightiner...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
Massey Ferguson 8200 Flex Platform (A59814)
Massey Ferguson...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
