PUMP for front end loader
   / PUMP for front end loader #1
KOREAN VET
Alvin,Texas
kubota L345 DT
HAS ANYONE TRIED TO USE A "PTO" PUMP TO OPERATED A FRONT END LOADER....I HAVE AN L345DT WITH A L1720 LOADER 1980 MODEL....THE ORG. FRONT PUMP HAS BEEN REPLACED SOOO MANY TIMES.....THE DRIVE SHAFT "SPLINE" IN GONE AND I HAVE TRIED MANY WAYS TO COUPLE THE PUMP TO THE ENGINE.... THOUGHT USING A "PTO" PUMP AT 1000 RPM MIGHT WORK.....OR ANY OTHER MODS.. THAT SOMEONE MIGHT HAVE TRIED AND GOT TO WORK......HELP.......
   / PUMP for front end loader #2
Are you just talking about putting done hydraulic pump on front ??? That's how most older tractors were done by. Yes you can
Oh and a heads up. You might want to get off the caps key. Some people will have your head for that
   / PUMP for front end loader #3
If a spline is getting chewed it's because 1 of 2 things, 1; something is not aligned or 2; lack of lubrication of the spline. Before mounting a pump on the front of the tractor you must ensure the pump you are fitting has the correct rotation and is speed rated for that application.
Hope this helps
   / PUMP for front end loader #4
Hope this helps
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
SKYJACK SJIII 3219 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3219...
KENMORE ELITE REFRIGERATOR/FREEZER COMBO (A51248)
KENMORE ELITE...
SET OF 51" HANG ON WHEEL LOADER FORKS (A51246)
SET OF 51" HANG ON...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
UNUSED FUTURE BC72 - 72" HYD BLOCK CRUSHER (A51248)
UNUSED FUTURE BC72...
