Pulling with a F150
/ Pulling with a F150 #1
BigJ
La Grange, TX
2007 Ford F150
Was looking for some advice on pulling a Nissan Titan with my 2007 F150. I have a towing package. Is it possible to pull on a car hauler for 50 miles?
Saw there was a post on how much someone had pulled with his F150 vs pulling with his Titan.
/ Pulling with a F150 #2
Should be no problem as long as it fits on the trailer. What is wrong with the Titan?
Chris
/ Pulling with a F150 #3
Should not be a problem. I have hauled several broke down pickups on my car hauler behind my 2005 F-150 with tow package. It handles the load well and according to the book, I am we'll within my maximum tow capacity. The only thing is that it will suck down fuel pretty fast with that kind of a load.
/ Pulling with a F150 #4
only issue I see is getting the truck sitting right on the car trailer for proper weight distribution eg tongue weight. Other than that should be no issue.
/ Pulling with a F150 #5
You won't have any trouble at all. I pulled a 5500 lb. travel trailer with my '05 F150 with no trouble. The Titan + trailer will weight a tad more, but will be much more aerodynamic. Check the brakes and air pressure in the tires on the trailer, strap the truck down well, and you'll be fine.
/ Pulling with a F150 #6
i've made pulls like that.
get the tougt right.. use correct straps a.. be safe and legal and go for it.
/ Pulling with a F150 #7
Chain it down good and tight and you should not have a problem at all if everything is in working order. Not sure what your temps are like in Tx but if it is good and hot maybe keep an eye on your temp gauge just in case.
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2012 Ford Expedition SUV (A64557)
2012 Ford...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
2024 Texoma 16ft. T/A Equipment Trailer (A64194)
2024 Texoma 16ft...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
