Pulling up fence posts?
   / Pulling up fence posts? #21
With enough helpers and a long enough lever etc.......
Unless you can come up with free help and a tractor those posts are still going to be expensive
   / Pulling up fence posts? #22
Go to You-Tube and type in T-Post Puller. There is a video showing a 3-pt apparatus that looks like a jin-pole and has a simple ratchet on the end. It slips over the post and when the 3-pt raises, it locks into the post (kinda like how a pipe-wrench works). Then he pulls a string attached to the ratchet after completed and it releases the post. Might be something you could weld-up yourself for alot cheaper. However, I thought you said the posts were embedded about 4-6 feet, if you, this might not work. At least it could raise them and then cut them off once you get near the top.
   / Pulling up fence posts? #23
I would try a 3pt pole lift and hook a nylon tow strap wrapped around the fence post attached to it, will grab better and not damage the fence post.
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59575)
2007 STERLING...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
207269 (A52708)
207269 (A52708)
WATER TRAILER (A58214)
Cargo Van (A59230)
Cargo Van (A59230)
