Pulling tree out with wheel & chain?
/ Pulling tree out with wheel & chain? #1
ning
Elite Member
Northern California
Branson 3520h
I've got a number of scrub oak that I need to clear out of an area, and I'd prefer to yank them out rather than just cut them short as they sprout suckers madly and I prefer to avoid poisons.
I've managed to pull out smaller specimens with my tractor using a chain - up to a few inches in diameter - but when they get bigger than this it's not doable, as these scrub oak have crazy strong roots. these aren't anything like a pine tree, which while it's got a tap root there's not a lot else and they come out readily just being pushed over (besides, cutting those is permanent)
I've seen people use an old wheel so that there's an initial upwards pull, and I have questions before trying to find a reasonable wheel for this -
1 - I'm guessing the bigger the wheel, the better? I tried using a piece of steel I-beam I had, but it was too unstable and fell over to the side before I could get enough tension on it (working solo) to have it do any good
2 - has anyone had luck with this wheel method pulling scrub oak or something with similarly obnoxious roots?
There's way too many of them to dig out with the backhoe.
/ Pulling tree out with wheel & chain? #2
Have you thought of cutting them flush then painting the freshly cut stump with stump killer? If you paint the stumps immediately after cutting the phloem bits of the plant still have enough energy to suck the poison up and kill the roots so no sucker shoots.
It's always a consideration, but as I mentioned in the op, I prefer to avoid poisons.
Besides environmental and philosophical concerns, I'd also like to plant fruit trees and berry vines in the area.
/ Pulling tree out with wheel & chain? #4
Great fun! It is an old, old technique for stump pulling. The older versions of the wheel used a post on a wood plate to keep the post from being driven into the ground; the chain goes around the stump, and up over the post to your oxen. ;) Generally, the post started off no more than 45 degrees off of vertical for maximizing upward force. (Sine of angle and all that.)
So, yes, a bigger wheel is better, but the goal is to translate horizontal force to vertical lift.
Can you get a ripping shank around the scrub oak roots to even the odds a bit before trying to yank them up?
Can you tie your I-beam to the chain for solo work?
All the best,
Peter
/ Pulling tree out with wheel & chain? #6
Ah yes, I missed that bit. Apologies
All the best,
Peter
The I-beam experiment was probably doomed from the start as I was working on somewhat of a side angle. I think if I welded a base to the I-beam to make it into an upside down T (maybe best to be an upside down "t" with a spike going into the ground?), it may work well enough - especially if there's a helper who can steady things while a bit of tension is added to keep it planted.
I've yet to get a ripper for the backhoe (Branson BH76; there's been a couple threads about getting rippers for it; maybe I'll contract with the welder down the road and have him make me one as my baby welder won't do that heavy of metal!) but that definitely sounds like a good start; I'm hoping to get at least some trees out without the backhoe being involved at all.. ideally it would be chain, yank, clear, repeat all day, I can fantasize can't I?
I'm kinda imagining getting an older big tractor wheel, possibly welding some bracing across on the inside if it's rusted up a bit, but honestly the I-beam/t-beam may be best as it's at least somewhat man-carryable.
I'll likely give this another shot after the next set of rains, if they every come, as I have doubts that the ground has absorbed enough moisture to make the yank possible. Blackberries are still holding tight.
/ Pulling tree out with wheel & chain? #8
If you do the I-beam thing, I would weld a hinge mechanism to the base plate, and a hole for a lash point at the apex to tie/bungee cord your chain on, and something to support the chain as it goes over the I-beam so as to not stress the chain. The vertical portion doesn't need to be big. You can lift a foot at a time and get the job done. In my experience, once it starts, you are golden.
Have you considered what might happen if the chain breaks? Could you double up on cables? Use a marine rope?
All the best,
Peter
/ Pulling tree out with wheel & chain? #9
The herbicide you paint on the stump will not effect anything else around it. By the time the flush stump rots out the hericide will be inert.
/ Pulling tree out with wheel & chain? #11
My neighbor just pulled a small stump using a spare pickup truck tire / wheel, with chain. It worked very well! We had to reset for a second pull to get the whole stump out, but all told it took maybe 2-3 minutes.
/ Pulling tree out with wheel & chain? #12
The herbicide you paint on the stump will not affect anything else around it. By the time the flush stump rots out the hericide will be inert.
Perhaps. It depends on the herbicide, the soil, and the climate. Where @ning is, many commonly used tree herbicides are persistent, e.g. garlon.
All the best,
Peter
tbh I'm not confident that what's claimed about herbicide safety is accurate
there's plenty of evidence that the manufacturers play fast & loose with the truth, and the truth only comes out later; i'm happier to put in the effort to do things the right way for me and the environment
/ Pulling tree out with wheel & chain? #14
Agreed. Witness Monsanto...
/ Pulling tree out with wheel & chain? #15
yup, take claims like that with a spoonful of DDT
I hadn't seen much elasticity from a chain break before, but decided to do a bit of a web search before making an ass out of myself here
and yeah apparently you can easily get killed by chains too, though they're way less elastic than wire rope & bouncy straps (not sure why people seem to think that kinetic recovery ropes & straps won't break either - if they do break, they're going to be worse than just about anything with all that stored energy in them!).
so
I'm thinking probably best to weigh down the pulling chain in at least a couple spots and possibly attach it to something to try to catch it if it does break loose.
/ Pulling tree out with wheel & chain? #17
so
Keeping the pulling chain close to ground level helps, as one of the videos above shows, but yes, it does end up being about stored energy. I have a couple of grade 70 chains that I use for important jobs, and a couple of pieces of larger, but ungraded chain that I use for random light weight work, where the chains might get dragged. I keep my grade 70s clean, dry, and off of anything that might stress a link when in use.
I vividly remember cutting a safety chain to length for a new to me trailer. I had to use 48" bolt cutters, and when the link finally parted the halves flew about forty feet. (Yes, I had to go find them. I knew they were sharp and we had horses that walked through the area.) I was/am amazed at the stored energy.
Stay safe out there.
All the best,
Peter
/ Pulling tree out with wheel & chain? #18
not sure the size of your tractor but if big enough a rootrake grappler would work… i have pulled aspen tree and willow trees and they also have very deep roots but my tractor as 60hp
/ Pulling tree out with wheel & chain? #19
I just pulled up a 12" tree few days ago. I don't use a wheel, just tie chain as high as I can reach. Used two chains 20' so tree wouldn't hit tractor. Pulled many with an old 4x4 truck I have around here. But, a storm came through and a big tree fell on it, haven't fixed it yet. I've pulled up trees so big that with 40' of chain the tree was still past my front bumper. Another thing, with a long chain, and I have one that is 43' long, you can back up and change direction of pull, seems to really help. I used an 18 wheeler rim once and was not impressed. Easier and quicker to just tie on and pull over.
/ Pulling tree out with wheel & chain? #20
I've seen a few videos of the rim pulling (working and going poorly), I would cut and spray, but, many people don't like the herbicides these days.
I am a little surprised you believe setting up the wheel and chain safely and pulling them would be faster than the backhoe, I would expect it to be double or more time than digging them?
Best,
ed
2022 EZ-GO ELITE...
iDrive TDS-2010H...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
