Pulling steering wheel part 2
/ Pulling steering wheel part 2 #11
Man, I don't know why anyone would want to cut a steering off /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
/ Pulling steering wheel part 2 #12
/ Pulling steering wheel part 2 #13
will a steering wheel from a ym 1510 fit on it?
Ernie
/ Pulling steering wheel part 2 #14
Ernie
Ernie,
Tried to return your call, but apparently you were out.
Don't know about the 1510. My steering wheel is mounted on a splined shaft about (can't measure it exactly) about 6/10 of an inch in diameter.
Turns out a wiring harness I ordered from Yanmar is backordered & won't be here as soon as promised, so I have a couple more weeks to fiddle with the steering wheel. And after asking around some more I am going to try a couple new ideas for pulling it without destroying it. If I knew yours would fit, I wouldn't hesitate to destroy it to remove it. We'll see.
Ernie,
/ Pulling steering wheel part 2 #17
if you have time make a better puller. get a piece of steel thick enough that it will not bend and notch it to fit around the shaft. take a gear puller and make pieces to bolt it to the blate. Then crank on the puller and tap the center bolt of the puller.
/ Pulling steering wheel part 2 #18
/ Pulling steering wheel part 2 #19
Excellent idea Normmm.
Eugene
/ Pulling steering wheel part 2 #20
Eugene
Coats 5060AX Rim Clamp (A61307)
Coats 5060AX Rim...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2013 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2DJ296618 (A61165)
2013 International...
2004 John Deere 4720 (A60462)
2004 John Deere...
159118 (A60430)
159118 (A60430)
