Pulling Large Shrubs
/ Pulling Large Shrubs #41
I can't believe all the people of TRACTORbynet who are so anxious to hand dig a shrub. Sounds like an ad for True Temper. This is a shrub, not a sequoia tree. If these shrubs were planted by someone, they will pull out easily, just like they were planted in a root-ball. I have done this with 20-year old landscaping...no sweat. Get a 5/16 grade 70 chain 20 feet long. Pull slow, fast, jerk, anything.... that 790 will NOT break it. (never seen a broken chain fly either) If you really want to dig, use the loader, that's what it's for.
/ Pulling Large Shrubs #42
Spoken like a true manicured lawn owner/operator/w3tcompact/icons/wink.gif. I bet some of us here are just speaking from our experience at pulling out large, overgrown weedy shrubs that we don't want. Invariably, if you want it to grow, it will practically jump out of the ground and die for you, but if you DON'T want it to grow, then it pretty much acts like that sequoia you were talking about. Probably a corollary to Murphy's law/w3tcompact/icons/tongue.gif
/ Pulling Large Shrubs #43
I have some "large shrubs" of my own to remove, here are the details. They are actually four Spruce trees, diameter at ground level is about a foot. They are 35-40 feet tall. I trimmed off all the branches as high as I could reach from the ground, maybe 8 feet high, to make it easier to work around them. Then last Saturday I used the box blade and dug down 1 foot all along one side of the four trees. In the process I cut through many roots, along with 10" of frost. There's nothing more satisfying than snapping off sub-terrainian roots with your box blade scarifiers, except maybe if you own a backhoe. Now, after the frost is completely out, I am thinking I can pull the trees over, by hooking on up fairly high for leverage, and pulling away from the excavated side. In my experience with smaller Spruces, I have found them to have a sprawling flat root structure and no tap root. I believe I have removed all the strength from the one side. Am I in for a shock when I start to pull on them? My choices for equipment include the 2000 pound tractor, the 4wd full size pickup, an 80 Hp tractor of probably 5000 pounds, or a come-along (hand ratchet winch) to a nearby tree. I cant remember the comealong capacity right now. I may start with that, just testing the trees.
Comments welcomed, there's still frost so I have time to change the plan.
/ Pulling Large Shrubs #44
Spruces do tend to have the sprawling flat root system that you mentioned. They should be easy to topple, but be careful that if they don't pull out easily, spruces tend to "shatter" into a lot of flying splinters. Make sure nobody is standing anywhere near the tree.
Larry
/ Pulling Large Shrubs #45
i cut the things down to about 6" above ground.
drill some holes in the stump.
wait a month to dry out, then burn out the stump.
/ Pulling Large Shrubs #46
I read your profile. Why isn't "stump burning" ahead of "dirt moving"?
First: when removing a tree, never cut it down.....use its mass to your advantage. When you are able to get it to lean at all, it will help in its own removal.
Second: who wants to wait a month?
Third: what kind of "forest creature" burns stuff in the woods?
Fourth: only YOU can prevent forest fires.
Pallet of Hay Tedder Tines (A64119)
Pallet of Hay...
UNUSED WOLVERINE SNOW PUSHER (A64281)
UNUSED WOLVERINE...
2716SFL (A61567)
2716SFL (A61567)
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
2011 Ford F-450 Crew Cab Mason Dump Truck (A61573)
2011 Ford F-450...
