pulling a white 348 plow
/ pulling a white 348 plow #1
ny
jd 1070
hi i have a koubota m 6060 4 wheel drive tractor loaded rears and front loader is my tractor big enougth to pull a white 348 mounted 3 bottom 16 inch plow thanks art
/ pulling a white 348 plow #2
should do fine
/ pulling a white 348 plow #3
I pull a set of 4X16 semi mount plows with an 8540, 4wd, loaded tires. It pulls fine in corn stubble, a bit tough in sod.
/ pulling a white 348 plow #4
as long as you gear down in low range & keep the power curve around 22-2400 rpm you'll be fine. if you bog down, choose a lower gear.... if you're willing to take your time & fine tune, you'll be just fine.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
BOWMAN WEED WICK & MOUNT (A63291)
BOWMAN WEED WICK &...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
