Pulling a T-Post
   / Pulling a T-Post #1
swines
Platinum Member
I discovered a buried t-post on a piece of land that I own in southern New Mexico. It is in an area where I want to expand the driveway into the propery and needs to be removed or othewise dealt with. It has about 10-inches of the post above ground and an unknown amount buried.
The ground is unbelievably hard. It is a mixture of small flake rocks from decomposed sandstone, some fines (sand and soil), and probably 25% caliche clay. The ground is nearly impossible to penetrate - I have NO idea how someone got the t-post in as far as it is. For example, we were putting in some geotextile and had to use rebar to make holes for the pins. It took about 30-40 full hits with a 3 pound hammer on the rebar to drive it 6-inches into the ground....we put in about 250 pins.....
For the t-post I tried: pushing it back and forth with my tractor using the bucket to loosen it - didn't budge just bent the post. Lifting up on the post using the bucket - didn't move. Pulling it out with my F350 4x4 in 4wd low range - didn't budge it an inch.
My next thought is to use my 10-ton porta-power to try and lift it straight up - or, lastly - dig around it with the back hoe and cut it off 10 or so inches below ground.
Any other ideas?
   / Pulling a T-Post #2
I like that idea best.
Use an angle grinder a few inches below grade. You will be done with it in a few minutes.
   / Pulling a T-Post #3
I ran into a similar problem at my old house. First time I mowed, BANG, I hit a hidden lenght of pipe in the backyard.
A stub, about 2" tall of 2" dia steel pipe. I dig down a bit and hook a chain to it, no luck. Push back and forth with the loader, no luck. Start digging.
Before I knew it I had uneathed at 55 gallon drum of concrete that was the base for some old clothes pole. I estimated where the 'matching pole' was hidden and ignored it!
Good luck with yours. If it was mine, I'd take the advice of cut it off low and bury it.
Keith in SC
   / Pulling a T-Post #4
Same experience as Keith01 on several occasions. Buried in a 5 gallon bucket or one that was attached to rebar as a deadman. Dug down a bit and cut would be my suggestion as well.
   / Pulling a T-Post #5
For "normal" t-post I have had good luck pulling them out with the bucket. Wrap a chain around the post about 4 times then attach to the bucket hooks. Lift straight out.:D
   / Pulling a T-Post #7
I got a real good laugh out of that Iron Horse. Thanks
   / Pulling a T-Post #8
Have you tried soaking the area around the post with water? I've had luck just letting a garden hose run overnight at the base of the immovable object and when I come back the next morning they pull pretty easy.
   / Pulling a T-Post
No water available at the site - still have to put in a well + bring in power.
Question: If you're "PitbullMidwest" - why does your avatar show a Bull Terrier?
   / Pulling a T-Post #10
When I joined I couldn't find a american pitbull terrier pic that I liked so I used an English bull terrier figuring most people wouldn't know the difference and over the years have just never changed it. In 7 years on TBN you're the first to notice or care enough to question it :)
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2011 RAM 2500 (A53843)
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
