Pullin Old Fence Posts
/ Pullin Old Fence Posts #21
Yep, you still have to get off the tractor and pick those suckers up too... might as well do it with a chain, then at least you don't have to bend over to pick every one up.
Digicamnut: Pics coming soon! Just got home...
/ Pullin Old Fence Posts #22
Before I had a tractor I found a chain wrapped around the post and then around a jack-all worked great. Just jack up the jack-all and the post comes with it as with a loader.
/ Pullin Old Fence Posts #23
For regular field steel fence posts I used a chain attached to one of the three hooks welded to the top of my bucket. Wrap it around and pluck it out. You may want to get some one to catch it when it comes out so you don't scratch your bucket:)
For serious fence posts like 4" x .25" , I used an angle grinder and cut it off below the surface and left it.
/ Pullin Old Fence Posts #24
Tain't neccessarily so...
My home brew attachment (previouisly posted drawing) holds on to the post so long as the post's weight is being supported. If you let the post's weight rest on a trailer or a pallet or the ground you can "jiggle" the FEL and release the post. Admittedly, I don't get 100% of the posts to stay on the pallet but I don't have to get out of the tractor to handle every post.
Pat
/ Pullin Old Fence Posts #25
patrick_g said:
Since my post puller of choice is the tractor/FEL and with the little attachment I welded up I don't usually have to get out of the tractor to pull a post so I don't get out and get down to manually wiggle the post either.
Neither do I. I walk down the line of posts prior to pulling any of them and wiggle each one a bit to loosen them up (6" posts). Then I walk the dog from one to the other...
/ Pullin Old Fence Posts #26
My T-post puller pics... This should be enough to get you started...
Enjoy!!
/ Pullin Old Fence Posts #27
Pat
That's good... I didn't think about having another trailer or a pallet or something tagging along.
/ Pullin Old Fence Posts #28
I took some 2 inch tubing and welded some ears on one end and drilled holes through both for a bolt. Then drilled holes through another piece where I wanted the leverage to be from. Then I put them together by putting the one piece between the ears and running a bolt through them. I then drilled a hole all the way through the second piece at the end of it. Then ran a bolt through it and welded it in. Heated it up and bent the ends up on both sides. Welded a foot for it to stand on then got some chain to wrap around the t post and used the welded bolt to pull the t post out of the ground. It' easy to make and does the job. Cost a little time to make.
I guess I failed to mention that the posts are from an old hurricane fence.
Brian... I think your puller would also work on these.
/ Pullin Old Fence Posts #30
I too use 6ft T posts and drive them fairly deep placing the top of the post just below the button on my shirt ((can I say nipple on here?)
Maybe your dirt holds posts better than mine. Every once in a while I run into a post that acts like it put down roots, but not often. If that were the average situatioin here, I'd no doubt be doing things differently, perhaps the way you do it.
Pat
/ Pullin Old Fence Posts #31
:rolleyes: :rolleyes: You can wrap an old blanket around the post too.:rolleyes: :rolleyes:
/ Pullin Old Fence Posts #32
texasjohn said:
Wow... that's a slick puller..... I may have to make me one of those.... but, maybe not...just too easy to wrap chain around the few posts I do from time to time.
Am I missing something? How do you "shuck" that post once it is pulled? Wouldn't you need a rope to a release mechanism to drop the post?
It's probably right in front of my face and I'm missing it.:eek:
EDIT: Duh! Watch the video Jim!
/ Pullin Old Fence Posts #33
Jim, I took a short scrap of pipe and some scrap metal, sized to fit over a T-post and welded a chain on it. Y put the chain on the FEL and it dangles down with the pipe ring at an angle between vertical and horizontal. You can drive up to a post and lower the ring over the post. When you pull up the piece of pipe tries to capsize and grips the little bumps running the length of the post. It grips pretty good and doesn't slip often but its grip depends on tension, i.e. the weight of the post holding down on the puller and its chain. If you lower the FEL and let the weight be partly carried by the ground the puller-gripper-thingy looses its great grip and can be jiggled a bit if needed and it will release the post. IT helps if you don't initially lower the gripper way down on the post, just grab it near the top.
Pat
/ Pullin Old Fence Posts #34
Patrick_g, I'm going to need a photo of your puller-gripper-thingy....can't seem to get a picture in my head...
/ Pullin Old Fence Posts #35
Easiest way is to watch a lazy man do it! Take a chain, hook to the bottom of the post, have an old rear tractor rim, preferably taller than the post handy. Place the chain OVER the rim, pull forward with car, lawnmower, horse, donkey, fat 2nd cousin or whatever. Wheel gives you the leverage necessary to pull the post out of the ground!:D :D
/ Pullin Old Fence Posts #36
digicamnut,
I dont' think I'm familiar with the posts you're talking about, got a picture? I could probably tell you if it would work or not, as long as the C plate will fit over it... but that could be "sized to fit" as well.
/ Pullin Old Fence Posts #38
Most people have mentioned using the loader to pull posts, which is what I also do. If you don't have a loader, the 3 pt will also work well and usually has much more lifting power for the really stubborn posts. Ideally, use a drawbar between the lift arms but you can also just wrap the chain around one lift arm and the post. It may require removing and reattaching the chain once the post is lifted part way to completely remove ithe post from the ground. Use a good chain because the lift power of the 3 pt can be much stronger than the loader. Many CUTs will lift 3-5K with the 3 pt. Our larger farm tractors will lift 15K+. Not many loaders will lift that much.
If any one is familiar with older hedge posts, those can be extremely hard to remove. They are very hard and usually curved and wider at the base than the top. The curve and wide base keeps them anchored in the ground and are harder to remove than any post.
I have never used a hand type post puller. I just can't seem them working well in our type of soil which can have clay.
/ Pullin Old Fence Posts #39
John, I posted a drawing a while back.
It really isn't complicated. It is basically a short length of scrap pipe with a chain welded to it.
Hanging from the chain, the axis of the pipe is diagonal WRT the world. The pipe is like a wide wedding band. It will slip over a T-post by gravity but when you pull up on the chain it cocks the pipe which catches on the bumps on the T-post and lets you pull the post.
If you lower the FEL till the post starts to touch the ground a little and jiggle the FEL a bit and raise it a bit the T-Post falls out of the grabber and you are ready for the next one.
My pipe was a little larger diameter than I wanted so I welded some scrap steel inside the ID to close the hole down a little so it grabbed batter when I pulled up on it.
I haven't used it (or seen it) for a while and don't really know exactly where it is. It would only take a few minutes to make another one. I'm no artist but I'll try to make a sketch, scan it in and post it.
Here goes...
OK, I fond some previous scans so posting an old one and a new one. Both designs work. The one with the scrap plate grabs better (fewer missed attempts) but doesn't release quite as easily.
Note: These drawings are not all that good to scale. Make a prototype and watch how it works and then make a better one. NOt much to these but they do work.
The commercial post popper I have, the one that works manually like a jack has a little attachment that grabs the post. You could duplicate that attachment and have a post puller that would work on flat posts AND T-posts.
Pat
/ Pullin Old Fence Posts #40
OK... I got it now..... thanks for the sketch....very functional, and all that I needed to understand .... I'm remembering that once I tried to use a pipe but it didn't catch the T post ridges.... maybe it was too long or something.... good idea! Thanks!
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2022 EZ-GO ELITE...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A64553)
2025 Wolverine...
JMR 8ft Man Basket Skid Steer Attachment (A64553)
JMR 8ft Man Basket...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
