Pulled the trigger!
/ Pulled the trigger! #21
We have the Kubota pin-type Quick-Attach for our loader (LA402 on a B2910)
When we bought the tractor, the dealer didn't have the Kubota pallet forks in stock ..... but did have a pair of Woods DUal pallet forks for a skidsteer which he was willing to give us a deal on ...
Since the pin-type mounting brackets on the Woods forks wouldn't work for our loader, I had a neighbor who is a welder fab up a pair of new brackets from some scrap rectangular tube. I had to ream/hone out the holes so that the pins fit properly (alignment) .... wasn't too big a deal ....
The Quick-Attach makes it far easier to change implements - although it is probably a little more sensitive to alignment than a typical skidsteer QA ..... dunno .....
I usually have to tweak the loader curl or lift to get the second pin in after getting the first one in .... on either the forks or the 60" light materials bucket.
I'm glad we have the pin-type QA ....... however ........
If I had it to do over again I'd probably spend the money on a skidsteer QA - mostly because it's my observation and understanding that attaching things would be even easier .....
When I'm working on a project with the tractor, I wanna be doing that - as opposed to messing around with trying to fight some implement to get it on the tractor so I can continue with what I'm really doing ..... don't much care for aggravation .... probably the reason I have a Speeco Quick-Hitch for the 3PH .....
Being able to use other (skidsteer QA) attachments is a secondary consideration and is less important ..... probably because alot of the attachments for skidsteers require high hydraulic flow ..... although being able to rent a skidsteer QA concrete bucket from the local rental yard could be kinda handy ....
I went ahead and ordered the ATI kit. I figured, who knows if I'll ever need to use a skid steer attachment, but I hate regret worse than anything. This way, I have it available, and have the QC capability as well.
Still seeking trailer.
Mike
Tomorrow's the day!
I think tonight is going to be like Christmas eve, when I was a little kid. Don't know if I'm going to be able to sleep. Cruel part is that I have knee surgery on Tuesday, won't have much time to play before I'm laid up, but doc says only about a week.
Will post pics!
Mike
/ Pulled the trigger! #24
If you have hills the wheel spacers are good. I got the Kubota QA and it is the best money I have spent. A thumb for the BH is pretty useful. If you are not going to have it on grass very often there is no reason not to load the tires. Bucket hooks are great and wont cost your dealer too much.
Get what you need now - it is easy to spread it over 5 years at no interest. If you are getting more than 5 years at zero percent make sure you are getting a good price.
Hi Donn,
I had them load the tires, won't be operating much on grass. I'm with you on the "get it now", with the zero rate, it doesn't add much to the payment.
Funny, a thumb is one thing I've been back and forth on. Thinking about seeing if they have one in stock when I go for my "walk thru" tomorrow.
No hills on my land, pretty much flat as a board, so the stability won't be much of an issue at home.
I got 7 years no interest, price was under the website "build your Kubota" price. Price I'm paying seems to be in line with what I'm seeing here.
Mike
/ Pulled the trigger! #26
Congratulations on you new Kubota. That's one sweet machine you've got there! :thumbsup:
Where are the pictures? :D
I got it! I got it!Wow is this sweet. Haven't had time to play much, did take some pix on the trailer at delivery, haven't uploaded yrt. It is sweet!!
/ Pulled the trigger! #29
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2016 Deere 60G (A60462)
2016 Deere 60G...
2020 FORD F-600 SERVICE TRUCK (A60736)
2020 FORD F-600...
2024 JCB 35Z-1 (A60462)
2024 JCB 35Z-1...
SANDBAG ATTACHMENT (A60736)
SANDBAG ATTACHMENT...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
