Pull gear
/ Pull gear #1
mffarmall
Colorado
Farm Pro 2425, MF 50, JD B, Farmall Super MTA
Look at the attachment. The beveled pinion says that there is 8 a ring that needs to come out then the 6 can be taken off. When I looked at 6 it has canals in it. In one of the canals there is a square blocking it from moving. Is this the ring? And how do I remove it to get to the bults. Or is it easier to just use a crows foot and remove the bults?
/ Pull gear
/ Pull gear #3
It looks like 6 is threaded and a spanner is the tool of choice.
/ Pull gear #4
/ Pull gear #5
Is the "square" one of the tabs of the lock ring (7)? It looks like that is the method used to keep 6 from turning? That sounds too obvious to me, probably you found the real reason by now. Sure looks like 6 threads onto the shaft, and 7 holds it in adjustment? Let us know.
Jim
/ Pull gear #6
Jim
/ Pull gear
Found it!
7 folds over into the canel on 6. All it needed was a push and a hammer to fold it back. Then it all came out. Thanks for the help. The ring gets bent over into the canals. I have an old Farmall and it uses half moons to block things. I guess that just looking at things on a new day really helps.
/ Pull gear
Found it!
240156 (A56859)
240156 (A56859)
2005 Fontaine Trailer, VIN # 13N1482C951524579 (A61573)
2005 Fontaine...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2007 CATERPILLAR 320DL EXCAVATOR (A63290)
2007 CATERPILLAR...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
PALLET OF HYDROLIC CYLINDERS (A63745)
PALLET OF HYDROLIC...
