Pull behind atv mowers
/ Pull behind atv mowers #1
goatman
southern ohio
NH TC 30
I have used my neighbors bush hog 42".. I would like to get something like it, but would like a 54-60" cut has any one ever seen one that big?? Thanks /forums/images/graemlins/smirk.gif
/ Pull behind atv mowers #2
I used to have an Agri-Fab 63" that I used to pull behind mine garden tractors. Worked great until I hit the end of fence post sticking up out of the ground. I replaced about $500 worth of parts including the belts it kept eating up after that. It also couldn't quite mow as fast as my NH TC-24. I bought it for $1,300. Had it about 2 years (only really used 1 as I hit the fence post beginning of the 2nd year). Spent $500 on parts and then finally sold it for $500.
Swisher also makes a 60" cut. It didn't seem to be as heavy built as the Agri-Fab unit, but I like it better as it floated on 4 large tires vs. the Agri-Fab with 2 and anti-scalp wheels in the front. I believe TSC usually carries the Swisher brand.
/ Pull behind atv mowers #3
My only experience is keeping the neighbors 'pull-behind' running for him. He goes too fast and his pull-behind wasn't designed for 'heavy' use. After several modifications, including beefing up the frame and the wheel axles, finally have a unit that seems to take the abuse. I prefer the 3pt variety, and like the unit closer to me, rather than stirring up things that can fly 'way out there', outside my comfort zone.
/ Pull behind atv mowers #4
I got a used Brush Hogg GT42 for free. Fixed up the deck with some angle iron + weld. New tires and a eng tune up. Cost about $150 bucks to get it running. 2nd time I used it hit a rock busted the blade spindle, $250 to get parts. Next time I used it the 10.5 HPmotor (briggs) tossed its rod. Found a left over 12.5 for $399 the extra power really helps. Keep two extra belts at all times. Now that I have the main areas cut back and rock removed it works like a champ. I would say we have ~ 25 hours on it so far. Its no tractor /brush hogg but it fills the void until I get one. theres another mdel on the market called Acreaze(sp) but the run $3500 no way would I take that trip!
/ Pull behind atv mowers #5
I have the Swisher 60 in. trail mower. I use it to mow about four acres of pasture behind my NH TZ 24. Not a real heavy duty unit but has worked well for me for about 25 hrs so far.
The Swisher 60", Is it study enough to keep a pasture clear ie small mutifloral rose and sage grass?? How much does it weigh?? Could you pull it with a Honda 300 4wd up gentle hills?? Thanks for your time.. /forums/images/graemlins/smirk.gif
/ Pull behind atv mowers #7
JUST CURIOUS, BUT why if u have a tc30 would you want a pull behind mower instead of a mower or brush hog for the tractor? /forums/images/graemlins/confused.gif
/ Pull behind atv mowers #8
Goatman,
You might want to take a look at the Kunz Engineering line of ArcEase mowers:
Kunz Engineering Products
They are designed with ATV towing in mind. Videos of the products in use are at:
ArcEase Mowers with ATV
Their finish mowers are 60" and their rough cuts are 57". They come in a range from homeowner to tough commercial. Prices are listed on the website. ATV tongue is available for about $75.
Good luck...
I am un comfortable with some of the slopes and the narrow width of the tc 30.. I am looking at getting 2 piece rims for the Tc30 before I purchace a pull behind mower.. but am considering the mower as a back up...And would like to go with 60 -63" if I can find under $1500.... /forums/images/graemlins/smirk.gif
/ Pull behind atv mowers #10
I pull a 60" swisher behind an 18HP craftsman lawn tractor to mow 5 acres of pasture. The tractor has a 42" deck so I get about an 8 foot cut on each pass. It works fine. We have a good mix of grass and legume and of course some weeds. I can let it grow to 5-6" and still mow it high without any problem. The acrease is a better built unit but costs a good bit more. I don't know what a Honda 300 is, but my garden tractor can pull the swisher easily up gentle slopes. Mine was $1299 at Farm and Fleet (like TSC) with the B&S engine.
Thank -You, I will go with this swisher If I can't get the rear end of my tractor wide enough to feel comfortable on the hills... /forums/images/graemlins/grin.gif
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Ford Truck Tire and Rim (A65640)
Ford Truck Tire...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Mini Universal Root Rake (A65640)
Mini Universal...
WinPower PTO Generator (A66408)
WinPower PTO...
1988 Mack R688ST (A62679)
1988 Mack R688ST...
