Pull-Back collar on PTO shaft
/ Pull-Back collar on PTO shaft #41
This is my take...
When I am fitting a pto driven attachment to any of my tractors, (Cat 1 and Cat II) , I first check the tractor pto stub for crud or corrosion, and give it a dose of some sort of lube, Usually penatrating oil, 'cause that's what I usually have handy.
Then I have a look at the attachment hook up. If it's a push bolt style, I exercise it a time or two, and if it needs lube, Well, There is that same can of penetrating oil. I make sure I don't have to fight the lock!
If it;s a slide collar, I do the same. Getting a feel for just how much effort I need to put into the locking collar to get it to open. Lube is my friend, along with exercise!
Then, With the tractor and attachment near to mated, I align the pto stub and coupling. Sometimes that means shifting the tractor pto drive out of engagement to get the stub to spin free. Seems that spinning a pto shaft is never easy!
I'm always amazed at how FAR into engagement the pto spline members travel before the locking element is encountered. But I do NOT open the lock until it is encountered!
I found I spent way too much effort holding the lock open prior to fitting the pto splines. WASTED EFFORT. Work without purpose! STUPID!
Do one job, then do the other when the time is right.
I do make a habit of pulling hard TWICE on the coupling after I "think" all is mated and secure.
I have been caught a few times, and glad for it!
Bottom line
Prep the parts, Divide the tasks, check you work!
/ Pull-Back collar on PTO shaft #42
Another thing to make slipping the prop shaft onto the stub easier is to regularly lubricate the telescoping inner/outer shaft.
What do you lube the sliding part of the shaft with? I used to use grease but it collects far too much dirt and soon the shaft is just about impossible to slide. At one point I washed all the grease off and now I just use WD40. It's probably not enough of a lube but all of my telescoping shafts slide very freely.
At the present rate of wear these shafts are not going to wear out in my lifetime. Also on most CUT sized shafts the telescoping parts are not expensive or hard to replace.
  • Good Post
Reactions: jmc
/ Pull-Back collar on PTO shaft #43
Grease only
Does yours have plastic shielding? Should not collect dirt if it does.
I do not like WD-40 for this application, but if it’s working for you, use it.
Yes, they eventually will. And when they grenade, better check the underwear.
The tractor end spun around like a steel baseball bat and almost took out all my hydraulic lines until I could get it to stop.
but why would you want to replace something that can easily be maintained?
/ Pull-Back collar on PTO shaft #44
All of mine are old and have the push-pin release. Even those can be cantankerous at times if not kept lubed.
I have a few of those I have gutted, then drilled out 1/2” and use a bolt and Nylock nut to hold them in place. Requires tools (I keep on tractors) but not much hand strength.
/ Pull-Back collar on PTO shaft #45
Grease only
Most of my implements do not have plastic shielding. It wears out over time and becomes a nuance and so gets trimmed or removed.
I don't concider this a safety issue as all my implements are 3ph and the pto is well with in the confines of the quick attach and mounting framework..
If necessary the shafts will be replaced long before they grenade. Since the plastic shields are gone they are very easy to inspect.
I can relate to the pto shaft whipping around. I was working for friends and the implement hitch broke. I looked back and the hydraulic hoses were stretched tight. They automatically released before any damage and I managed to get the pto shaft stopped before it was damaged. Your right, check your shorts.
"but why would you want to replace something that can easily be maintained?" Because my body is worth something too and I feel that eventually replacing part of a pto shaft is a very small price to pay vs the frustration of fighting a shaft on and off because the grease is all stiffened up with dirt. And contrary to your recommendation the dirt does accumulate under the plastic shield. I've been there and that's why the shield doesn't get replaced after it's worn out.
/ Pull-Back collar on PTO shaft #46
I guess I must not use mine enough, but I use Lucas Red & Tacky on mine ... Wipe off any grease/dirt before putting the shaft back on the tractor ...
/ Pull-Back collar on PTO shaft #47
I’d recommend replacing the shield. Safety is important, but I’d be more concerned with rust seizing up the inner & outer. I’ve read a few stories where this happens and operator doesn’t realize it and when it won’t slide in/out, bad things can happen.
I’ve never seen dirt accumulate to any noticeable degree under plastic shielding.
My large square baler is not equipped with shielding on the first shaft. It is the Comer brand and it does however, come with “coated” inner and outer shafts to make the mating surfaces more rust resistant and slide in/out easier. Coated shafts are pricey.
/ Pull-Back collar on PTO shaft #48
HD I hear what you are saying about rust but you and I live on opposite sides of the continent. You live in a high humidity area and I live in a semi desert. On a good year we might hit 10-12 inches precipitation including the snow. I store all of my equipment inside and here rust is just not an issue. Unless.... you leave it outside for ten years.
/ Pull-Back collar on PTO shaft #49
I don’t have as much trouble with the pull back collars as many of you have reported but yes for me they are a royale pain and I highly prefer the older fashioned push button type, just don’t understand why so many manufacturers have switched to the sliding collar type ?
/ Pull-Back collar on PTO shaft #50
My newest equipment (Chipper and Ditch Mower) both came with push button releases on their PTO shafts. The chipper is going on three years old and the ditch mower is one year old now. Is that "Old Fashioned" these days? :ROFLMAO:
/ Pull-Back collar on PTO shaft #51
I didn’t know that. You are prolly ok then.
I keep most of my plastic shielding in good shape. I actually have to fix my tedder shielding this winter.
/ Pull-Back collar on PTO shaft #52
The PTO shaft is very heavy on our HD mower and it is hard to hold it up and push the shaft forward and pull the collar back. You are fighting yourself. Have you son and DIL hook it up! Or use lots of lubricant on the sliding shaft and the collar and spline.(used motor oil) I also have a file that just fits into the splines and I dress them when they get buggered. Regardless, they are a PIA!
/ Pull-Back collar on PTO shaft #53
Just buy a tractor for each attachment
Problem solved!
/ Pull-Back collar on PTO shaft #54
If I see it right, the smooth round pull back locks are just that much less likely to catch and hang up on chains, ropes, twine, gloves or clothing.
I could be wrong, but those things are pretty difficult to catch up on.
/ Pull-Back collar on PTO shaft #55
The problem I have with my slide back collar is that it is located on the mid mower shaft going to the mid pto location underneath my Kubota BX2230. I have to lay on the mower deck with my shoulder, reach up and around the rear tire to slide on or release it for removal. Can't get a second arm or hand in there to help. Rear pto, no problem, it is easily accessible. Jon
/ Pull-Back collar on PTO shaft #56
Different tractor, same problem. I slide under the tractor 3 pt hitch & get closer to the mower deck. Gives me good access to the collar
/ Pull-Back collar on PTO shaft #57
Not enough room under the three point and rear axle. Jon
2005 LEEBOY 685B MOTORGRADER (A62129)
2005 LEEBOY 685B...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
DRIVEWAY ENTRY GATES (A60736)
DRIVEWAY ENTRY...
832636 (A61166)
832636 (A61166)
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2009 FORD F-150 (A60736)
2009 FORD F-150...
