pto
chevy2ford
I just got a Zetor 6245 with FEL.
When I push the lever to engage PTO it spins but I can grab it with my hand and stop it.
Are there other levers to engage pto?
Does anyone know whats wrong?
Please Help !
Forgive me if this is too obvious. Are you depressing the clutch first, then engaging the PTO? If you just move the handle, it may jump out of gear when it starts to move and it is just slowing down - hence you can stop it with your hand. Depress the clutch, engage it and see if it holds. You can disengage without using the clutch.
Also, it the machine new? Mine was not engaging and I found the fork that engages the PTO had worn to nothing - replaced it and was back in business in no time. Merry Christmas & good luck.
Maybe I'm just a sissy but I would never grab a spinning PTO shaft!:eek:
Me either. Rotating machinery injuries are one of the quickest and most deadly. If you or your clothing was ever grabbed by the shaft or spinning guards, you would be sucked in so hard and fast you'd never know what hit you.
Andy
Please Help !
Question completely off - what made you to go with Zetor?
Tried that once and flipped the tractor on it's roof when the shaft stoped lol!
My brotherinlaw has a zetor. Seems like a nice tractor.
I doubt that it is jumping out of engagement but it's could be. My guess is that it has another lever that engages gears between the transmition and the pto. The lever you are using is simply a clutch that is attached to the gears on the pto side. It turns because the gears are close together and the dive gear is making the pto gear move with the transmision oil that it is moving but when you grab onto the pto shaft, the oil cannot keep the pto gear turning. Unfortunately, I don't know if there a gear engagement on your tractor or where it is.
Welcome to tbn chevy2ford,and Merry Christmas. I can't answer your question but I would call the dealer if you don't get it figured out.
I'd also like to invite Dirthog over for a "stump pull" I have a couple that are too big for my tractor.:D
oscer could do that I have a 28000# excavator that works quite well on them
No way Jose! That's asking for trouble. I've seen quite a few PTO blunt trauma, burns, and just plain nasty PTO injuries!:eek:
Hey, I've got about 50 trees I'd like to get rid of. You wanna swing by?
I think we've become a little bit too preoccupied with the grabbing the PTO thing to focus on the question at hand. (No pun intended)
Hey chevy2ford - Merry Christmas! Any update for us - surely you're not making merry while your poor ol' tractor has a problem - are you?
I bet it does,all I have is a JD 4110 with fel,but it sure beats the way I was doin it a couple of years ago,with a diggin iron and an axe.
Hey chevy2ford good luck with your pto problem
Sissys!! :D :D I'd of course only grab it if I tried to stop it with my foot and tennis shoe first....and I slowed it down.
I imagine grabbing it by hand.. even if it was only freewheeling is a great way to ind out if there is a metal bur on the shaft...
Soundguy
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
8' x 6' Galvinized Shed (A66408)
8' x 6' Galvinized...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
KUBOTA M108S TRACTOR (A64277)
KUBOTA M108S...
20ft Phelan Lowboy Trailer (A65563)
20ft Phelan Lowboy...
