PTO Won't stop turning
/ PTO Won't stop turning #1
Jenkins003
Bronze Member
Although my Century 3040 tractor has a little over 200 hours on it the PTO was never used. I just took the plastic shield off today. I noticed the pto shaft constantly turning while the tractor was running with the PTO lever disengaged. I can hold the shaft with my hand and it will stop turning while I am holding it. Is this something to be concerned about or is this normal for the Century/Branson tractors ?
/ PTO Won't stop turning #2
That's pretty much normal for a lot of tractors... it's just the friction/oil drag in the driveline causing the shaft to turn... nothing to be alarmed about at all.
/ PTO Won't stop turning #3
Sounds right to me as well.
/ PTO Won't stop turning #5
Yeah same with my tractor, My Zetor tractor has the same problem. It won't stop turning. I don't understand why but thats normal.
I just noticed today that after I adjusted my clutch my PTO shaft doesn't turn when not engaged. It works the way it's supposed to now.
/ PTO Won't stop turning #7
While disengaged the PTO will stop under slight load (holding it with your hand) but it should stop.
2025 48in Rotary Brush Cutter Mini Skid Steer Attachment (A66734)
2025 48in Rotary...
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2020 Ford Explorer AWD SUV (A66738)
2020 Ford Explorer...
