PTO won't engage
/ PTO won't engage #1
2515R Dude
Platinum Member
KY
Branson 2515R
The first time since i bought it i tried to engage PTO.
I turn the nob, the indicator light goes ON, i hear some noises from the transmission but the PRO is not spinning.
Any thoughts?
/ PTO won't engage #2
There is a lever on the left side of the seat, behind the range lever. On a 2515, it has 540 and Neutral position. Put it in 540, then turn the switch on in the Ind position.
/ PTO won't engage
Yes, just found it as soon as i posted this. . The life is hard for idiots :cautious:
Good thing it does not happens often.
Thank you anyway, you are a real help and throve of knowledge.
Why do they need two????
/ PTO won't engage #4
Since there is a spring actuated brake in the PTO clutch pack, that lever allows you to put it in Neutral so you can spin the PTO shaft by hand which helps tremendously when hooking up PTO implements.
It also gets a 540Eco position in the 30HP and above models, which is another great feature.
1990 Chevrolet P6000 Command Center Step Van (A64556)
1990 Chevrolet...
1991 Polar MC 312 General T/A Chemical Tanker Trailer (A64194)
1991 Polar MC 312...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
3097 (A63117)
3097 (A63117)
2022 EZ-GO ELITE...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
