PTO Wobble
/ PTO Wobble #21
U-joints create a speed variation. Here is a graphical representation for a 30 degree shaft angle - shaft varies in rotation speed from 850 to 1150 rpm twice each rev for this example. That's why the u-joints are phased on a drive shaft - opposite end at the same phase angle cancels the acceleration/deceleration - but the shaft sees the speed change and they wobble. Your posthole auger has a very large u-joint angle so speed changes in the shaft are extreme, but as the input shaft on the gearbox is at roughly the same angle as the pto shaft on your tractor, there is no speed change at the auger and it runs pretty smoothly.
/ PTO Wobble #22
Suggest you check the indexing of your PTO driveshaft uni joints as they may be out of phase
You may also wish to join Aussie/NZ Kubota BX Owners Facebook group as you'll find a lot of 'local' knowledge available for us Aussies.
/ PTO Wobble
Thank you all - didnt realise speed variation and phasing was even a thing! The alignment looks to be correct though from what I can tell. Hopefully it is just the angle as mentioned - I've tried it on a small test hole and it seems to operate okay so fingers crossed! Appreciate all the advice
/ PTO Wobble #24
That PTO shaft only runs 540 rpm so it should be fine.....run it.
/ PTO Wobble #25
Its just the shroud. if the shaft was bent it'd be shaking like crazy. I guarantee its fine.
Yep. Shaft is straight. Look at the shroud where the two pieces meet. No wobble at all.
/ PTO Wobble #26
my thought is some of the wobble is in the U/joins when you lower it down the wobble will be less or none
/ PTO Wobble #27
I don't think PHD u-joints are past maximum angle. I wonder if condition of PHD u-joints has been checked lately?
Have you ever wondered similar to me how the u-joints on a 4WD pickup that had a very high lift kit installed survive those extreme angles at high rpm's?
if the lift is done correctly they should change the angle to align the shaft/ U-joints
/ PTO Wobble #28
Actually, if there's no double cardan joint involved, the two shafts are parallel. Then the amount of difference between the shafts is limited by the max angle the joint can run. Most single joints max out at 15 degrees.
/ PTO Wobble #29
I see nothing to worry about. AS long as the shaft halves can slide in and out of one another....no worries
/ PTO Wobble #30
This is interesting to me as we have a lot of loose rock here and it's definitely going to be an issue - the BX25 at idle though doesn't have any real hydraulic flow/pressure (not sure about the terminology) and the PTO leaver is basically engaged or not, so I'm not sure I'll have much ability to slow it further than shown in that video which was only reasonably low engine revs from memory
I have a BX24. I understand this comment about hydraulic flow/pressure at idle e.g. the loader and three point don't work until you get some RPMs up.
But I think the PTO must work differently. I have a logging winch and even at idle it pulls significant weight and can stall the engine if I get hung up.
Doug in SW IA
/ PTO Wobble #31
We have an auxiliary front mounted PTO on our Massey 1705 we use for the snowblower. One year we didn't have the blower tight enough and the vibration not only detonated the shaft, it blew up the rear axle.
Expensive oops
/ PTO Wobble #32
I used to hate to use my brush hog, becsuse it vibrated too much. Come to find out my shaft was bent since the day I bought it.
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2022 EZ-GO ELITE...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2016 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 VOLVO VNL 6X4...
(1) UNUSED 26X12.00-16 TIRE W/ 5 LUG RIM (A64280)
(1) UNUSED...
Caterpillar D7H Series 1 and 2 Dozer Service Manuals (A63117)
Caterpillar D7H...
