PTO Water Pump
/ PTO Water Pump #1
SuperDutyDave
Vermont
Deere 5525 Cab-MFWD Deere 244J Loader
Anyone know where one might buy a reasonably priced PTO driven water pump...only ones I have found have been for huge applications and priced in the $5K+ range!
Can't believe you can buy a good trash pump with good lift and good PSI for around $1K but you can't buy a PTO pump for the same or less...it doesn't have a motor!
Any help would be appreciated...
Thanks
SD-Dave
/ PTO Water Pump #2
Try asking in the attachments section, you should get more responses as this is not a JD specific question...
/ PTO Water Pump #3
If you are looking for a PTO pump similar to what one would use for a sprayer, you can get them at your local Tractor Supply store. Depending upon what you are looking to do, you can also buy an electric pump and run it off the tractor (Be sure you don't overdraw power from the system). I have a 60 gallon Femco sprayer that I pull with my 2210 that I mounted a electric pump on the front that seems to work just fine.
Kubota M4700 (A60462)
2017 International Prostar 122 Day Cab (A62613)
2017 International...
(3) Corral Gates (A66408)
(3) Corral Gates...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2015 Bobcat T590 (A64126)
2015 Bobcat T590...
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
