PTO stump Grinder
/ PTO stump Grinder #21
I saw one made from an old brush hog gearbox in Farm Show. These have slip clutches and or shear pins for some protection from big hits.
It was mounted on a 3 pt carry all frame and had a steel plate base. The grinding wheel itself was made much as has been described here. two heavy circular plates weldeds together one a little larger than the other with teeth from Baileys. Im guessing in the 12-14 inch range
He had a hystat and he would just go back an forth over the stump lowering it a bit each time.
Looked good and he said it worked well.
Horns (A64557)
Horns (A64557)
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
1200 gal Water Wagon (A66408)
1200 gal Water...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A64553)
2007 JLG 600HJ...
New/Unused IREV Two Wheeled Electric Vehicle (A65583)
New/Unused IREV...
