PTO Sound When Engaged
   / PTO Sound When Engaged #1
cdaigle430
Maine
MF GC2410
Hi,
I just engaged my mid and rear PTO for the very first time just out of curiousity. No problems to engage or disengaged but when I first engage either one I hear a rapid clicking noise that sounds like the wheel of fortune whel spinning. Then it goes away-is this normal?
   / PTO Sound When Engaged #2
Mine doesn't make any sound like that...but that doesn't mean it isn't normal on your Massey-Ferguson.
Easiest way to find out is run down to your dealer and ask them to engage the PTO on another GC2410.
   / PTO Sound When Engaged #3
Hi,
I don't have that noise. I use mine with the KK rotary cutter. Do you have anything attached to the PTO? Maybe just freewheeling, w/o something attached it does that.
Thanks-nothing yet. Just trying it to make sure it works.
   / PTO Sound When Engaged #5
I had this happen on my Kubota L2800 HST and called the dealer. He said it was normal. I am new to tractors though.
   / PTO Sound When Engaged #6
I have a GC2310 and it sounds like what you describe when the main PTO lever is engaged without any of the other two levers (540 & 2000).
I posted the question here a while back and concluded that it was normal. My tractor is now over 500 hours and still works like a charm if this can reassure you.
   / PTO Sound When Engaged #7
I have no clicking noises from mine with either PTO engaged.........and no noises when operating both PTO's at the same time.
   / PTO Sound When Engaged #8
Ditto Max2310: Mine will make that clicking noise as well, but only if the PTO clutch lever is engaged without one of the two speed levers engaged.
Solution- I engage either the 540 or the 2000 first, followed by the clutch lever, and disengage in the reverse order. No odd noises then....:D
Thanks
Ford 345C Tractor with Loader (A51573)
Ford 345C Tractor...
John Deere Z915E Zero Turn Mower (A51573)
John Deere Z915E...
2013 Chevy Silverado 2500 HD (A53472)
2013 Chevy...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
