PTO Sound When Engaged
   / PTO Sound When Engaged #1
cdaigle430
Maine
MF GC2410
Hi,
I just engaged my mid and rear PTO for the very first time just out of curiousity. No problems to engage or disengaged but when I first engage either one I hear a rapid clicking noise that sounds like the wheel of fortune whel spinning. Then it goes away-is this normal?
   / PTO Sound When Engaged #2
Mine doesn't make any sound like that...but that doesn't mean it isn't normal on your Massey-Ferguson.
Easiest way to find out is run down to your dealer and ask them to engage the PTO on another GC2410.
   / PTO Sound When Engaged #3
Hi,
I don't have that noise. I use mine with the KK rotary cutter. Do you have anything attached to the PTO? Maybe just freewheeling, w/o something attached it does that.
Thanks-nothing yet. Just trying it to make sure it works.
   / PTO Sound When Engaged #5
I had this happen on my Kubota L2800 HST and called the dealer. He said it was normal. I am new to tractors though.
   / PTO Sound When Engaged #6
I have a GC2310 and it sounds like what you describe when the main PTO lever is engaged without any of the other two levers (540 & 2000).
I posted the question here a while back and concluded that it was normal. My tractor is now over 500 hours and still works like a charm if this can reassure you.
   / PTO Sound When Engaged #7
I have no clicking noises from mine with either PTO engaged.........and no noises when operating both PTO's at the same time.
   / PTO Sound When Engaged #8
Ditto Max2310: Mine will make that clicking noise as well, but only if the PTO clutch lever is engaged without one of the two speed levers engaged.
Solution- I engage either the 540 or the 2000 first, followed by the clutch lever, and disengage in the reverse order. No odd noises then....:D
Thanks
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
LOOK! (A53342)
LOOK! (A53342)
2021 Chevrolet Silverado 4500HD / Silverado 5500HD Flat Bed, VIN # 1HTKJPVK3MH814615 (A51572)
2021 Chevrolet...
